460 pistons
Old Apr 11, 2001 | 05:03 PM
tbolt 460's Avatar
tbolt 460
460 pistons
did the 460 ever come with flat top pistons with valve reliefs
Old Apr 12, 2001 | 04:10 AM
cobrajet's Avatar
cobrajet
460 pistons
sure. all of the older motors can with flat tops, that's how they got the 10:5.1,, and 11:1.1 compression ratios. i've taken several of these old motors apart to find flat tops. even the 1972 429 i took apart had flat tops. C.J.
Old Apr 12, 2001 | 03:32 PM
tbolt 460's Avatar
tbolt 460
460 pistons
flat top meaning,flat with 2 or 4 valve reliefs,not a dished piston.Cause the auto parts stores dont list a flat top piston for a 460
Old Apr 15, 2001 | 06:11 AM
tbolt 460's Avatar
tbolt 460
460 pistons
I've got more responces saying that the 460 NEVER had flat top pistons,the 429 did.The C8VE,C9VE are head-block #'s the C8SE could be the 429 flat top.Can some one please verify with a whole part number.One person said if the 460 had flat tops it would have waaaay to much compression.HELP
Old Apr 15, 2001 | 06:55 AM
dinosaurfan's Avatar
dinosaurfan
460 pistons
T-bolt, have you called Ron Miller at Ford Power Parts? His guys used to sell a flat top (no bathtub dish!) pistons for the 460. I believe he used TRW very dished 429 slugs and cut the tops flat. His shop makes all sorts of custom pistons for Fords, using TRW forgings as a starting point. FPP made my 060 over 410 pistons from L2291Fs, which are supposed to be for a 390. Doesn't Kieth Black offer some 460 flat tops too, in hypereutechtic? DF
Old Apr 15, 2001 | 07:13 AM
tbolt 460's Avatar
tbolt 460
460 pistons
I know i can buy aftermarket,but did FORD ever put them (FLAT TOP) in a 460.Some say yes and more say no,make up my mind and others.
Old Apr 15, 2001 | 11:27 AM
dinosaurfan
460 pistons
arkredneck
Dec 5, 2015 06:40 AM
Dr. Driveway
Sep 18, 2015 09:30 PM
TobaccoBarn460
Aug 15, 2015 11:10 AM
rudifisk
Jul 2, 2015 08:48 PM
