Help Me Identify this 460
Old Jun 28, 2015 | 06:13 PM
rudifisk's Avatar
rudifisk
I have a 1973 F-100 with a 70' era Lincoln smog motor. I need to identify which version of the 460 this is so I can make some choices for heads and cam to get it putting out some reasonable HP. There is an aluminum tag on the intake and here are the numbers:
460 72 10
10-15 K866 T
Or maybe the second row is instead:
0-15 K866 T
What I really would like to know is if this motor has flat top pistons or dished pistons. And if it has a zero deck height or something else.
Thanks for any help!
Old Jul 2, 2015 | 11:45 AM
cbakker's Avatar
cbakker
Originally Posted by rudifisk
I have a 1973 F-100 with a 70' era Lincoln smog motor. I need to identify which version of the 460 this is so I can make some choices for heads and cam to get it putting out some reasonable HP. There is an aluminum tag on the intake and here are the numbers: 460 72 10 10-15 K866 T Or maybe the second row is instead: 0-15 K866 T What I really would like to know is if this motor has flat top pistons or dished pistons. And if it has a zero deck height or something else. Thanks for any help!
If it is a 70's smog motor it does not have a zero deck. Those numbers say nothing about the motor. You need to find the casting numbers on the side of the block.
Sent from my iPad using IB AutoGroup
Old Jul 2, 2015 | 08:48 PM
TobaccoBarn460's Avatar
TobaccoBarn460
From HP Books "Rebuild Your Ford V-8" by Tom Monroe 1980:
"The engine code number used by the Ford parts man when he's ordering parts is found on a tag or decal attached to the engine."
"Up through Feb 1973, tags were mounted at the front of the engine. They are usually sandwiched under the coil-mounting bracket, the dipstick tube bracket, or under the water temperature sending unit."
"Beginning in Feb. 1973, the metal tags were replaced in favor of a decal on the right-valve cover at the front."
On casting numbers:
"When a component such as a cylinder head or block is cast, a number is cast in the part and is appropriately called a casting number. Casting numbers are extremely helpful when identifying an engine and it's parts.
Unfortunately casting numbers are not 100% accurate because castings are frequently machined differently, thus generating different part numbers which don't appear on the part! To make matters worse, it is conceivable these parts won't interchange. Consequently a parts casting number in conjunction with it's physical design must be used to identify it."
Was just reading this last night, it's probably not going to help, but I thought it was an interesting bit of information out of the past.
In a chapter about the interchangeability of parts between engines.
Hazard48
Mar 21, 2013 11:07 AM
kenny nunez
May 25, 2012 06:56 AM
Klxrider
16
May 28, 2008 11:07 PM
turbo2256
Apr 23, 2005 10:59 AM
