If you have limited slip diff, I believe you do. I understand that even motorcraft factory diff oil used for expeditions is synth, so using mobil 1 synth would not negate the need for it.
Hopefully not. It's suppose to prevent diff clutch chatter. I'm reading the book about the theory of operation, and the clutch works/compensates when one tire is slipping. I hope you didn't tow off road or in slippery condition
You're good, just get a bottle as soon as you can and put it in there. This is a dealer only item, I believe. That's where I got mine.
By the way, while you're under your truck, it may be worthwhile to check the vent tube on top of the diffrential shaft if you have one, I found mine on the driver side.
Somebody posted here that it got clogged, possibly causing rear wheel seal leak.
thanks i'll check it out. I had it on the road the whole time. so i hope to get it done tomorrow night. We have 2 more fights this truck week and this has to pull the ring. it's about 5500lbs.
yeah i have a LS. It's on an FX4. H6 axle code 3.73 LS. I like this ratio alot since I've been pulling a trailer. Has anyone had issue with the rear axle? This is my first IRS.
Ford specifies 75w140 synth in both open and limited slip diffs, front and rear axles through out the light truck line through super duty. It is also the in service replacement for FHLP gear oil found in earlier models.
That's not what my manual says for my 2002 Super Duty. Front axle is spec'd at 75W-90 for the Dana 50/60. Only the F250/F350 SRW are spec'd at 75W-140 synthetic for the Sterling 10.50 rear axle. The Dana 80 (F350 DRW/F450) are spec'd at 75W-90 synthetic and the Dana 135 (F550) is spec'd at 80W-90.
I had my seals done at the beginning of summer and I am not sure if they put friction modifier in when they changed the fluid. Is there any way to tell? symptoms? It is an 03 XLT with 3:73 LS. I am a little concerned now.
If only ford could build F150 and expedition axles as well as the super dutys. I go through so much 75w140 on those with there leaking seals. dont rember the last super duty that had any axle work done other then the std. brake job. forget that they do vary there oil weights. when in doubt check your axle tags.
R
Check your work order slip and see if it's listed.
