Flywheel Casting Number
Old Jul 23, 2007 | 12:12 PM
kellar's Avatar
kellar
I found a flywheel with the casting number E8TR-AA. I believe it is a manual flywheel for either a 302 or 351 but I am not sure. Can anybody help me out?
Old Jul 23, 2007 | 12:57 PM
HemiEater's Avatar
HemiEater
I think thats a 50oz 5.0 flywheel.........
Old Jul 23, 2007 | 08:19 PM
kellar's Avatar
kellar
That is what I figured it was. I was hoping for a 28.
Old Jul 29, 2007 | 12:25 PM
kellar's Avatar
kellar
I found another flywheel. This one is supposed to be a 28oz from a 78 302. The casting number is D7TE-GA. Is this the proper flywheel?
Old Jul 29, 2007 | 05:25 PM
HemiEater's Avatar
HemiEater
should be ok 78 was 28oz balance.......check the tooth count.....
Old Jul 29, 2007 | 05:55 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D7TE-GA is not listed for 1978 and later 302's.
D7TE-GA = D7TZ-6375-C .. Fits: 1973/77 Bronco 302 / 1973/77 F100/350 302. 164 teeth
This flywheel (D7TZ-6375-C) was also used on 1973/74 351C 4V Mustangs & Torino's.
This is a typical example of Ford updating a part number.
Source: 1973/79 Ford Passenger Car Parts Catalog / Section 60.4 / Page 11.
E8TR-AA = E8TZ-6375-D .. Fits: 1988/89 302 F150/250 & U150 (Bronco). 164 teeth
The same flywheel ring gear = C5AZ-6384-A is used on both flywheels.
Old Jul 29, 2007 | 07:32 PM
kellar's Avatar
kellar
Thanks alot for the clarification guys
Old Aug 2, 2007 | 06:16 PM
stroker393's Avatar
stroker393
I've got to do a clutch / flywheel upgrade; just got a flywheel (D7TZ-6375C or D7TE-GA). The right size for my application; 11" / 164 tooth with a 6 1/4" bolt pattern for the pressure plate (6 bolts / 3/8"-16 thread). This bolt pattern doesn't match my current bad plate that I'm replacing. The new flywheel has several patterns on it but not drilled for them. Bill had posted several applications for this flywheel so I'm assuming FORD drilled the flywheels different for the applications. I don't really want to tap new holes if the new clutch I purchase doesn't match the current ones - which application would this flywheel fit according to Bill's list? I'm searching the net looking at all the clutch companies but haven't yet found any real answers to the differences in patterns.
Old Aug 3, 2007 | 03:48 PM
DaveBB's Avatar
DaveBB
Hi. This looks like the right place to ask this. I have a flywheel cast number
C6ZE - 6380 - A and stamped into it is the number C7ZE - B . It has 157 teeth. The od of the teeth is about 13 1/4"
I'd like to know if it's OK to use on the 289 and what clutch is right for it. It would also be great to know if it will work with the bell housing number
C5AA - 6394 - B.
Thank you, Dave.
Brian460
18
Oct 15, 2023 09:00 PM
Subvet21
Mar 22, 2016 09:11 AM
tommygirl
Oct 29, 2013 04:53 PM
Broomfieldbum
Sep 5, 2010 04:55 AM
broncoman66
Feb 2, 2003 03:31 PM
