H2E Vs. Turbonetics
Old Jul 22, 2007 | 10:57 PM
Badluck's Avatar
Badluck
H2E Vs. Turbonetics
Ok so i want one or the other i found the turbonetics at BWD for 1650 with ceramin coating and high flow outlet, or I can get a whole H2e kit with all the pieces i need for 2400 Which am i going to be able to build more power with whats going to be better for me??
Old Jul 22, 2007 | 11:43 PM
Badluck's Avatar
Badluck
Anyones thoughts or oppinions or even sorta kinda thoughts that may or may not be right are appreciated
Old Jul 23, 2007 | 12:19 AM
hedhntr's Avatar
hedhntr
how about the garret
Old Jul 23, 2007 | 12:43 AM
Badluck's Avatar
Badluck
is it better
Old Jul 23, 2007 | 12:48 AM
Badluck's Avatar
Badluck
i know its more $$ but is it really that much better I personally think the turbonetics is just as good or better than it, but how do those compare to the H2E
Old Jul 23, 2007 | 06:05 AM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
i think , and what i heard about Turbonetics is that those are much BETTER units than garett BB turbo, so they say it should be fine with injectors up to stage2 , more you have to go with H2E, thats what i was told , so thats why im running H2E, i cannot give you any info which would be a better unit, but if you end up wanting MUCH more than H2E might be a better platform for upgrades, thats all i can say,,,,,,,
Old Jul 23, 2007 | 06:53 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
the turbonetics drop-in replacement will work just fine with stock injectors, and will also support 400hp. However with the H2E it will not spool very quickly, it will be less streetable than the turbonetics. However it will be a big turbo that you can grow into. Personally i'd run bigger injectors with a small turbo and then upgrade air once i had the fuel.
white Buffalo
Nov 20, 2008 07:35 PM
Mr. Bob
Jun 26, 2008 11:47 PM
justblowin'smoke
18
Nov 7, 2007 09:59 PM
Ford79
18
May 18, 2007 04:37 PM
00Powerstroke
Oct 17, 2006 10:21 AM
