A/C Issues
Old Jul 22, 2007 | 03:08 PM
tdyl69's Avatar
tdyl69
A/C Issues
I have 99 explorer sport and the A/C is only spitting out warm air. I brought one of those recharging kits... but no luck. Any suggestions?
Old Jul 22, 2007 | 07:54 PM
JerrySimm's Avatar
JerrySimm
First some analysis. Is the compressor turning on when you run the A/C? Is your blend door moving to the correct position? etc.
Old Jul 22, 2007 | 08:02 PM
steve(ill)'s Avatar
steve(ill)
when you turn on the AC, the freon compressor clutch should lock up an dstart turning-- look at that first. next you need a pressure gauge at least for the low pressure side. you should have about 100 psi of gas inside when the compressor is off. when it starts running, the pressure will pull donw to about 35 psi and the high side will go to 250-300, if you have that gauge. if you have under 100 psi not running, or less than 35 when it kicks in, then you need more gass. if the compressor is not turning, it could be no gass, or bad electric.
Old Jul 22, 2007 | 08:13 PM
tdyl69's Avatar
tdyl69
I brought this kit with a guage and filled it to 45 PSI, which is the normal max while the ac is blowing max. What's weird is it will go up to 45psi... you hear a quick click from the engine... which drops the psi low.... then starts building back up to 45... then click... it drops suddenly then starts building again... over and over
Old Jul 22, 2007 | 08:14 PM
tdyl69's Avatar
tdyl69
whats a blend door
Old Jul 22, 2007 | 10:51 PM
JerrySimm's Avatar
JerrySimm
you are describing a system with low pressure, not enough R-134a. The pressure reaches an equilibrium without the compressor running. The the clutch clicks in and the compressor makes high pressure on one side of the orafice and low pressure on the other. Then when the pressure gets to low, a switch that protects the system from low pressure cuts the compressor off, the pressure equalizes and the cycle starts over again. You probably need more freon, but more than that, you need to know where the old freon went. Look at getting a can of freon with a flourescent dye, then you can check for leaks with a black light.
Regarding a blend door, it is the diverter device inside your dash that selects hot or cold air. This does not appear to be your problem.
Old Jul 23, 2007 | 05:15 AM
marragtop's Avatar
marragtop
You should consider getting the system completely evacuated and recharged. If you don't evacuate it, you can damage the compressor by continually adding gas.
Old Jul 23, 2007 | 08:45 PM
tdyl69's Avatar
tdyl69
This is what I do not understand... The can states that I should have the ac blowing max. and load up the r134a till 45psi. what i noticed is that as the low pressure hits passed 45psi and into the yellow, it shuts down and starts rebuilding....so in theory, it isn;t shutting down becasue it is to low....it is shutting down because it moved into yellow....correct?
Old Jul 23, 2007 | 09:03 PM
JerrySimm's Avatar
JerrySimm
No, you're connected to the low pressure side when charging, so when the compressor runs, the pressure should drop and when the compressor cuts off it should increase. Also, if your system has gotten air in it, all bets are off. As the air will never condense into a liquid at the temperatures and pressures within an A/C system, the pressures will not react correctly realative to the temperature curve for R-134a.
Old Jul 23, 2007 | 09:18 PM
tdyl69's Avatar
tdyl69
so it sounds to me I should get it professionally done....
Old Jul 23, 2007 | 10:39 PM
JerrySimm's Avatar
JerrySimm
Probably so at this stage
Old Jul 24, 2007 | 07:29 AM
marragtop's Avatar
marragtop
Go and get it checked out. Just be glad that you have R134 and not R12!!
