460 pulley problem?
Old Jul 22, 2007 | 03:26 PM
  #31
FordMan2's Avatar
FordMan2
Smile
Well guys I made a 1/4" shim and put it directly behind the balancer, now the pullies line up great! I do however think you guys are correct about the water pump it is probably the wrong one because there are no other excuses. Is one pump aprox. 1/4" longer than another one???? does anyone know? that is probably why the guy had the belt loose when I bought the old truck to keep the belt from flying off, this is the only thoughts I can come up with. I would like to Thank everyone that donated there time on this thread, it is greatly appriciated!!!!! this site sure rocks!!!!!!!!! Thank You
Old Jul 23, 2007 | 05:04 PM
  #32
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Bottom Line = You have the WRONG waterpump pulley.
The number you posted: 1VE-8509 is incomplete, it should read = D1VE-8509-AA. Ford part number D1VY-8509-A. The is a 3 sheave (belt) pulley. The parts catalog for 1973/79 F Series trucks with a 460 calls for a 2 sheave pulley (except CA trucks 1973/76). This means that not only is the pulley incorrect, but the belts are routed incorrectly.
The same 460 waterpump is used 1973/79 for all trucks and cars: D8TZ-8501-B.
The crankshaft outer pulley ID number (D0SE-6312-B) you posted translates to the correct 3 sheave crankshaft outer pulley (D0SZ-6A312-B) the 1973/79 Ford Light Truck Parts Catalog calls for.
>>>You need a 2 sheave waterpump pulley that measures between 6 1/8" and 6 3/8" in diameter. There are two different ones listed. With or without A/C.<<<
The pulley you now have is for a early/mid 1970's FoMCo 429/460 passenger car. It was NEVER used on F Series trucks.
Old Jul 23, 2007 | 05:37 PM
  #33
Mil1ion's Avatar
Mil1ion
Fordman.. I just got back to this thread.
Did you not see the obvious difference between your WP Pulley and my WP pulley ?
3 vs 2 sheaves .
Old Jul 23, 2007 | 05:47 PM
  #34
78'Ranger's Avatar
78'Ranger
I just put in a 460 in my truck and mine line up...here a pic...hope it helps somehow...Pic is angled but they do line up lol.
Shot with KODAK CX7430 ZOOM DIGITAL CAMERA at 2007-07-23
Old Jul 23, 2007 | 05:57 PM
  #35
mark a.'s Avatar
mark a.
Same set up I have too. 3 on the bottom, 2 on the top.
Old Jul 23, 2007 | 06:06 PM
  #36
78'Ranger's Avatar
78'Ranger
O I forgot to mention that my motor is out of a pass. car. Thats why it has the small pulley inbetween the larger ones for a smog pump...and it seems like u have a pass. car pulley...
Old Jul 23, 2007 | 08:36 PM
  #37
FordMan2's Avatar
FordMan2
WHOWWW! guys you are awsome! I guess I need to get another pulley, Thank you guys for the help
Old Jul 23, 2007 | 08:39 PM
  #38
78'Ranger's Avatar
78'Ranger
try a junk yard/auto dissmantalers...easiest and cheapest way to get a pulley. Just make sure that you pull the right one off...429/460 are pretty easy to find in 250...also look for 4V intake and make sure the intake isnt aftermarket...but finding aftermarket parts in junk yard is a little unusual...bring extra cash cause you usually find extra "goodies."
Old Jul 23, 2007 | 08:52 PM
  #39
banjopicker66's Avatar
banjopicker66
Do like I did - go serpentine!
I put the serpentine system from a '92 or so 460 onto my '86 460 in my '66 F-100.
Old Jul 24, 2007 | 02:44 AM
  #40
NumberDummy
With or without A/C? Let me know. I'll not only give you the correct part and ID numbers, but do a nationwide search for a new original.
Dennis Torres
May 1, 2017 12:24 PM
donthekawguy
Jul 30, 2016 07:35 PM
beartracks
Jul 4, 2016 12:23 PM
Boss50
WTB - Parts & other
Jul 1, 2016 06:00 PM
Montync
Apr 20, 2016 07:14 PM
