Modular V10 (6.8l)
0741 & 0744 lean codes
Old Jul 21, 2007 | 12:12 PM
DShira's Avatar
DShira
Im getting lean diag codes for both banks on my 2003 V10 with 37000 miles.
Can anyone tell me what could be causing them??
I checked vaccum lines for bad connections or cracks.
I had a K&N filter but have since gone back to the stock filter setup.
Appreciate and ideas..
Old Jul 21, 2007 | 02:13 PM
captchas's Avatar
captchas
Guest
p0741 is for your torque convertor clutch and p0744is also for the convertor. sorry guy but it's time for a rebuild. the convertor is gone and most likely has sent pieces though out the trans and pluged up the cooler at the same time.
check out our web site www.level10power.net and click on codes and that shows what you need for the repair.
Old Jul 21, 2007 | 05:58 PM
DShira's Avatar
DShira
Well I transposed the numbers. -- its codes p0171 and p0174 Sorry -
Can you give any advice??
Old Jul 21, 2007 | 09:12 PM
broncobilly66's Avatar
broncobilly66
mine did the same thing a while back....it was the PSV elbow on top of the intake it was rotten....had a hole the size of my little finger in it . u gotta take the TB cover off to see it
Old Jul 21, 2007 | 09:13 PM
keith w's Avatar
keith w
Both banks lean, I'd be checking for a vacuum leak first. Sounds like unmetered air is entering the engine
Edit: And as broncobilly suggests, the PCV would be a good place to start.
Old Jul 21, 2007 | 11:08 PM
DShira's Avatar
DShira
Thanks I'll check it out tomorrow
Old Jul 21, 2007 | 11:42 PM
Fordfreak_24's Avatar
Fordfreak_24
Check the plug on the bottom of the air box. Same happened to me.
Old Jul 22, 2007 | 06:03 PM
DShira's Avatar
DShira
The plug was the problem -- Jiffy lube I suspect when they checked the filter.
Thankx for the help all
Old Jul 23, 2007 | 02:48 PM
Fordfreak_24
I glued mine on cause it kept falling out. It never wanted to stay after it fell out the first time. Just a heads up!!!
BassFantasizer
Modular V8 (4.6L, 5.4L)
19
Mar 31, 2023 03:08 PM
Octane
1997 - 2003 F150
17
Oct 6, 2017 10:32 AM
jamesp39082
2004 - 2008 F150
Jan 4, 2012 08:40 AM
wildabeast
1997 - 2003 F150
May 27, 2010 09:31 AM
DMHG
Nov 7, 2004 11:44 AM
