Rough Idle, Lean Code..Help!
Old Aug 30, 2011 | 08:43 AM
jamesp39082's Avatar
jamesp39082
My 04 F150 has started having a rough idle. While in park the engine will stall out with the A/C off. Also when in drive the truck will idle close to 1000rpm's. I had to the fuel filter cleaned and also the MAF sensor cleaned. Also did a vacuum check on it. Pulled the code and it's throwing a Lean Code. What else should I be looking for? Thanks
Old Oct 3, 2011 | 10:31 AM
danguazap84's Avatar
danguazap84
rough idle
i am having the same issue, only my truck turns on and is ok when in park but trembles as if its trying to guage itself on how much gas to pass. I am thinking it maybe the throttle body or the AIC.
Old Oct 3, 2011 | 12:23 PM
Coskid's Avatar
Coskid
How bout some more information on your trucks such as year and mileage there may be something you aren't thinking of.
Old Oct 4, 2011 | 11:22 AM
danguazap84
year and mileage
2005 stx with 69500 miles
Old Oct 4, 2011 | 01:24 PM
Coskid's Avatar
Coskid
Did you clean the fuel filter or replace it? These filters are recommended to be replaced every 24-30k miles on them. If you did replace it make sure they put the right one on. There are two filters for these trucks and people have installed the wrong one before.
Other then that I am at a lost as to what else to tell you to check.
Old Oct 5, 2011 | 07:45 AM
Crf45or1991's Avatar
Crf45or1991
On my truck there was a bad gasket between the throttle body and intake man
Old Oct 6, 2011 | 01:07 PM
scoony's Avatar
scoony
I have a 2004 F150 with 96,000 miles. I have been having issues with it throwing lean codes, occasionally having the check engine light flash (a bad thing), and missing.
Changed the sparkplugs
Changed the fuel filter
Changed the cam position sensors
I had the Ford Dealer do the dianostic check and they said only thing they could find was noise from the cam phasers, and would cost $1400 to replace. Been doing some research and getting a mixed bag or results with the cam phaser thing. I am wondering if it may be the VTC solenoids that control or supply oil pressure to the cam phasers. Those are something I could handle and would be a lot cheaper than replacing the cam phasers, just not sure what direction to go at this point. Sometimes the truck runs fine, other times, it misses and runs rough.
Old Dec 30, 2011 | 07:21 PM
drewskins's Avatar
drewskins
cam sensors
what and where are the cam position sensors? I have changed my solenoids but still throwing a P0012 and have a rough idle
Old Dec 30, 2011 | 09:24 PM
scoony's Avatar
scoony
They are located on the front of each head
One of my problems was a bad sparkplug so I switched back to the Motorcraft plugs
I still have a CEL on but the truck is running fine otherwise
Old Dec 31, 2011 | 04:39 PM
drewskins's Avatar
drewskins
are they easily accesible or do I have to remove the valve cover etc.?
Old Dec 31, 2011 | 04:44 PM
scoony's Avatar
scoony
No need to remove anything other than the old cam position sensors.
They are small sensors that are visible on the front of the head. I think that there is only one bolt holding them in.
Old Jan 1, 2012 | 10:09 AM
BF750's Avatar
BF750
Do you have a K&N or similar air filter? If so, get rid of it, then remove the throttle body and thoroughly clean it with carb cleaner and a tooth brush.
These filters allow the oil & dirt to build on the TB.
I replaced the MAF & TPS to no avail. Was looking at the EGR etc. By luck, I was talking about this at lunch, another worker heard and pointed me in the right direction.
So come that night, 20 minutes & half can of carb cleaner later, problem resolved!!!
Hope this helps!
Old Jan 4, 2012 | 08:40 AM
BF750's Avatar
BF750
88PONY
Sep 30, 2015 06:11 PM
Brutl_Force
1997 - 2003 F150
17
Aug 20, 2011 03:44 AM
ssrider
2004 - 2008 F150
Nov 4, 2010 11:37 AM
ranger_runner
1983 - 2012 Ranger & B-Series
Sep 23, 2009 11:02 AM
litt810
Feb 25, 2005 10:54 PM
