Sponsored by: Real Truck
99 F250 Trailer Brake Controller Problem
Old Jul 21, 2007 | 10:28 AM
Big D's Avatar
Big D
I have a 99 250 with an aftermarket brake controller. I only use a trailer occasionally - a couple times a year. The last time I used the controller, the trailer brakes would only operate when I used the override lever on the controller itself. They will not work when the brake pedal is applied. Everything else (lighting) works fine. Any ideas? Thanks for the help.
Old Jul 21, 2007 | 02:00 PM
aldridgec's Avatar
aldridgec
More details. Type of controller, settings, etc. Sounds like something is not set right to allow the brakes to work effectively
Old Jul 21, 2007 | 02:08 PM
F350-6's Avatar
F350-6
Sometimes it's a loose connection or a bad ground. Try unplugging the trailer and plugging it back in. What type of plug are you using and where is it located? I've seen corroded connections inside the plug. Also some 6-way plugs have a tendency for the pins to squeeze together where they will not get a good contact.
deerhunt799
All Things Towing
Oct 3, 2017 01:29 PM
Wildcat313RE
6.7L Power Stroke Diesel
Apr 2, 2017 04:20 PM
tracyclifton
Jul 9, 2015 11:08 AM
Brute440
May 5, 2015 07:39 PM
Brian0445
Oct 20, 2008 04:46 PM
