Ford Integrated Brake Controller
Old Apr 2, 2017 | 02:04 PM
Wildcat313RE's Avatar
Wildcat313RE
I recently replaced some electric brake parts on my fifth wheel trailer. I used the brake controller to test my brakes with my 2014 F-250 in park and two wheels (one side) of the trailer off the ground. The brakes worked fine on the trailer. However, with the truck still in park I tested a second time using the brake pedal only and the trailer brakes did not work at all. Is this normal, does the truck have to be in drive and trailer moving to engage the trailer brakes using the brake pedal only.
Old Apr 2, 2017 | 02:18 PM
2civicrr's Avatar
2civicrr
I don't recall the details but there are some threads saying that or something similar.
Old Apr 2, 2017 | 02:38 PM
MPD56's Avatar
MPD56
It is normal
The intergrated brake doesn't activate with the pedal under a certain speed, this for one will stop jurking. Using the slide manual switch on the TBC bypasses the truck's control.
Old Apr 2, 2017 | 04:20 PM
Wildcat313RE
Thanks for the quick response! There is not much in the owners manual that talks about how the brake controller operates so I was not sure.
Miclaro
Feb 2, 2019 04:03 PM
Headviking
6.4L Power Stroke Diesel
Oct 17, 2014 10:35 AM
RussF350
Mar 27, 2010 10:29 PM
f350-fan-tum
All Things Towing
Nov 7, 2005 09:28 PM
gohan
All Things Towing
Jul 30, 2002 12:18 PM
