Front end play?
Old Jul 19, 2007 | 11:21 PM
1nascar24fan's Avatar
1nascar24fan
Question Front end play?
I was wondering how much play should the tie rod ends have?How much should you be able to push them in or out?Also ,how do you check the ball joints on a 2 wheel drive truck? Thanx for the help!!
Old Jul 19, 2007 | 11:26 PM
VQ2Fast4U's Avatar
VQ2Fast4U
Ive never checked my tie rod ends, but I dont think they should have much play at all. If you want to check you balljoints jack up one wheel at a time, grab the top and bottom of the tire then push and pull. See if theres any play, shouldnt be any or very little.
Old Jul 19, 2007 | 11:37 PM
1nascar24fan
Thanks VQ2,I,ll try that. It seems like i have the washboard feeling in my front end. I have new tires and shocks but still feels shaky!
Old Jul 19, 2007 | 11:49 PM
VQ2Fast4U's Avatar
VQ2Fast4U
Did you change your tires and shocks because of this problem, or did it happen after?
Old Jul 19, 2007 | 11:57 PM
1nascar24fan
After 64,000 miles on my factory tires i thought it was time. I didnt notice it too much till after the swap.I went with the Goodyear silent armor tires and monroe reflex shocks,I just started driving the truck on a reg. basis as the wife got a new vehicle,I only got to drive it when we towed our 5th wheel, that sounds bad!
Old Jul 20, 2007 | 07:23 AM
Derekj's Avatar
Derekj
You may also get your wife to sit behind the steering wheel and rock the steering with the engine off while you lay on the ground and look at all the steering components for looseness. I was shocked at my results and had to replace my track bar,both drag links, weld a bracket to house the stabilizing bar as the bracket had broken off, and finally got it re alighned with new ball joints. Now it drives like new.
Cheers Derek
mbootag
6.7L Power Stroke Diesel
Oct 15, 2012 05:46 PM
bbussman40
Jun 23, 2010 12:17 PM
Marc150
Apr 13, 2008 07:36 PM
herrfixit
May 10, 2006 08:04 PM
swenson
1978 - 1996 Big Bronco
Sep 18, 2002 11:21 AM
