impeller shaft play howmuch
Old May 10, 2006 | 07:02 AM
herrfixit's Avatar
herrfixit
Yesturday at the end of an on ramp the trans up shifted RPMS came down and I heard that awful BUZZ sound a bearing makes, I went home and checked end play at the impeller shaft and there is a little bit of play how much is toooooo much
Old May 10, 2006 | 07:48 AM
BuickTurbo's Avatar
BuickTurbo
Contact this dude. He is a god when it comes to hairdryers.
John C. Craig
(Considered one of the best Turbo Specialists)
Limit Engineering
Bells Island Cuwituck, NC 27929
Phone (919)232-3194
FAX (919)232-2149
Old May 10, 2006 | 09:21 AM
rickgmi's Avatar
rickgmi
The play is measured with a dial indicator, on the thousanths of an inch..if you see play you have to much..
Old May 10, 2006 | 05:53 PM
herrfixit's Avatar
herrfixit
Thank for the replies I would guess about 1/64-1/32 play
Il give him a call tomorrow
THNX
Old May 10, 2006 | 07:48 PM
Fat Diesel's Avatar
Fat Diesel
I've heard that a lot of play is normal. Does the inside of the housing look like it is making contact?
Old May 10, 2006 | 07:56 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
if you can push the compressor wheel (by the 5/8" head on the end) all around with reasonable force and NOT contact the compressor shroud at all, you will be fine. i checked mine when i rebuilt my turbo, and on the end of the shaft i had about .025" play RADIALLY. axially (in and out) i had .001" which was not bad, but optimum axial clearance is .000-.0005".
here are a few pictures of how i measured mine. sure it won't be as easy on the truck, but here is the basic idea-
http://img.photobucket.com/albums/v3...t/DSCF2871.jpg
Old May 10, 2006 | 08:00 PM
rickgmi's Avatar
rickgmi
Those are nice and tight, Im thinking if you have enough play to see it move you may have problems, say it gets warm then you might not have the clearence you might think when its cold, ....is there a certain number to go by when it is cold...
Old May 10, 2006 | 08:04 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Radial end play can't be measured with a dial with the housings installed. Press and rotate on the radial shaft from both sides of the turbo, if either the compressor or turbine wheel contacts the housing the bushings are bad. The axial end play limits (according to Ford spec's) are .02-.10mm (.00079"-.00394")
Reckitall
Jun 12, 2016 05:38 PM
Kj.keiscome
Nov 25, 2015 11:41 AM
jeffh
Nov 11, 2015 11:58 AM
Awitte58
Ford Truck Parts for Sale
Jul 8, 2015 02:47 PM
jinxie
May 24, 2014 08:31 AM
