7.3 shutting down
Old Jul 19, 2007 | 08:40 PM
CounterMaker's Avatar
CounterMaker
7.3 shutting down
ok my sisters b/f said his 99 7.3 just shut off when he merged onto the freeway yesterday...well he replaced the cam position sensor and thought it would be fine and then today he said it would sputter a little and than eventually shut off...when he pulled into work it shut off again when he put it into neutral...his dad is taking it into the dealership tomorrow to try and figure it out but i told him i would come ask you guys so his dad can go with some ammo!! thanks in adcance
Old Jul 19, 2007 | 10:00 PM
firefighter1204's Avatar
firefighter1204
I would say cam sensor, but you already tried that?
Old Jul 19, 2007 | 10:02 PM
firefighter1204
Trucks also have a low oil presure sensor that shuts them down.
Old Jul 20, 2007 | 09:16 AM
Beerstalker's Avatar
Beerstalker
I have heard of people getting bad new cam sensors. I would try one more, and then start looking into other problems. You might also try posting this question in the 7.3L section.
Old Jul 20, 2007 | 09:24 AM
ryaneverk2's Avatar
ryaneverk2
Moved to 7.3L PSD section.
Old Jul 20, 2007 | 10:06 AM
99SevenPoint3's Avatar
99SevenPoint3
i would double check to make sure the cps is placed on correctly or as stated try another cps its only,what $25 bucks ...last resort dealer but im pretty sure other ppl will have better advise...
Old Jul 20, 2007 | 11:19 AM
clintbonnie's Avatar
clintbonnie
Could be the fuel pump is going bad.. How many miles on the engine?
Old Jul 20, 2007 | 12:22 PM
StrokedRanchero's Avatar
StrokedRanchero
My '99 would do similar things. Even threw a camsensor code. It turned out to be a engine harness issue. Driver' s side engine harness was routed over the engine lift eyelet and chaffed a wire or wires , and would short causing the engine to just shut down while driving or not start at all. cheap easy fix, it just took patience checking connections. Good luck.
Old Jul 20, 2007 | 03:24 PM
CounterMaker
THANKS RYAN!!! alright ill print this thread out and give it to him...its just he is in WV now and his truck is here...his truck has aroud i wanna say 120k...ill post back around tuesday when i find out the verdict when he gets back...for now i guess i just continue to miss my truck and enjoy driving my sisters jeep
Copperhead75
51
Jan 30, 2015 07:50 AM
Mustang6147
Aug 11, 2010 06:21 PM
preppypyro
Jun 24, 2007 11:40 AM
Smokin'
35
May 28, 2007 11:01 AM
83 F350
Jan 12, 2004 12:55 AM
