Leveling Kits
Old Jul 18, 2007 | 12:06 PM
zacher12's Avatar
zacher12
Leveling Kits
I have a 89 Ford F150 2wd. I want to put a leveling kit on it but I can't find one for my truck anywhere. If anybody knows where I can get one I would greatly appreciate it.
Old Jul 18, 2007 | 12:25 PM
92F150Flare's Avatar
92F150Flare
Welcome to FTE
Summit Racing and Jegs have shackle and rear drop kits. Google their catalogs. Some of our sponsors up top might have them too......I use Summit a lot......good prices. LMC Truck is another one I use.
Are you just dropping the rear?
Good Luck
Bob
Old Jul 18, 2007 | 12:33 PM
GRAVEYARDSHIFT's Avatar
GRAVEYARDSHIFT
Theese guys got them! Im doing my 96 and already had these in my favorites .
http://www.stylintrucks.com/part.aspx?partid=24244
http://www.gcustoms.com/shopping_cart.php
Pat
Old Jul 18, 2007 | 01:17 PM
zacher12's Avatar
zacher12
I want to raise the front
Old Jul 18, 2007 | 01:39 PM
92F150Flare
ahhhhhhh..........you want to lift it in front..........more than stock?....or is it just sagging bad and you want back to stock?
I've seen posts here where new springs got a 2-3 inch "raise" but back to normal from sagging.......
you could use a heavier front spring.......F250......maybe 4X4........to get the raise beyond stock height. Depending on how high.......you'll be stretching your shocks out too....
Body lift might be something to look at too.
Old Jul 18, 2007 | 02:45 PM
Hawthornecustoms's Avatar
Hawthornecustoms
get the front springs out of a 4x4 bronco. should level you on out
Old Jul 18, 2007 | 03:51 PM
Pkupman82's Avatar
Pkupman82
According to the part numbers in my LMC catalog there is no difference in height of front springs on 2wds and 4wds. I am thinking about doing the same to my 96 2wd... I just hate the raked look that these trucks have. I have seen spacer kits and leveling springs available. I really like the ride of my stock springs, I am leaning towards the 2" spacers. FYI if you decide to do the front lift, don't forget to also get a pair of adjustable camber bushings.
Old Jul 18, 2007 | 08:13 PM
btoohey44's Avatar
btoohey44
The only reason I was going to lift the truck was because of the raked position it sits in and was hoping one of the 2.5" lift kits would level out the truck.
But if I could just bring the front up to the backs height I would be much happier.
cpl_kinder
May 22, 2011 07:42 AM
67vdubya
2004 - 2008 F150
17
Sep 14, 2009 04:24 PM
Lariat02
1997 - 2003 F150
Jan 19, 2008 07:02 PM
xidj
Jun 21, 2004 02:24 PM
jetmech2001
Nov 9, 2001 08:28 AM
