Sponsored by: Real Truck
Self locking tailgate
Old Jul 17, 2007 | 08:06 PM
F350-6's Avatar
F350-6
My tailgate keeps vibrating itself locked when I drive over bumpy roads. Since I don't want to move anyone know how to fix this. I've taken the cover off the inside of the tailgate and adjusted the latch several times but it still locks itself about 70% of the time.
Old Jul 18, 2007 | 09:54 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
One suggestion I can think of would be to remove the latch/lock assenbly and there should be a lever that pivot on basically a rivet. Support one side, say on a vise or anvil and use a ball peen hammer or a flat round punch to flatten the rivet thus making it tighter. I have done this on several items like the the tailgate latch/lock assembly with great results. Of course start off with light blows or you will basically rivet it solid and it wont pivot. It will take a little more effort to lock it, but it sounds like that is what you want. Good Luck.
Semper Fi! 1371 MOS
Old Jul 19, 2007 | 08:22 AM
Biggziff's Avatar
Biggziff
How about installing one of the remote, electric locking kits for the tailgate? The solenoid should keep it from unlocking.
Old Jul 19, 2007 | 05:07 PM
truckeemtnfords
I agree the electric lock would fix the problem, as I have one on my truck, but the cheapest fix is to tighten the rivet so it does not move so easily.
Old Jul 19, 2007 | 05:29 PM
F350-6's Avatar
F350-6
I didn't know you could even get an electric lock for the tailgate. How is it wired in? How does it affect removing your tailgate. I take the tailgate off kinda regular to load the truck with a forklift.
Old Jul 19, 2007 | 05:53 PM
truckeemtnfords
I bought my kit from Summit Racing and installed in about 1.5 hrs. It has a plug at the rear near the tailgate so you can unplug it and remove the gate like normal. As far as wiring you drop the wire out of the bottom of the tailgate and run the supplied harness along the frame, through the firewall and the two wires splice into the factory door lock wires below the door sill plate on the driver's side. The tailgate locks when the doors lock so your tailgate can't be removed by thiefs. It unlocks with a double push of the remote, or one push of the door mounted swicth, just like the extra doors on the truck. Nice piece of mind knowing some turd just can't walk up and steal you tailgate.
Old Jul 19, 2007 | 07:00 PM
F350-6's Avatar
F350-6
I have that security now. I can't even steal my tailgate without going and getting my keys. There was a miscommunication with my dealer so I have aftermarket remote locks on my doors which have lately seemed to eat their batteries pretty quickly. I'm having to unlock my doors about 30% of the time with the key and about 75% of the time on my tailgate.
If it's wired into the remote on the doors I think I'll pass on that option and try playing with the rivet. I think I'll order that keypad on the door of my next truck. I used to think that was kind of stupid but am really warming up to the idea now.
Old Jul 19, 2007 | 08:33 PM
truckeemtnfords
According to some of the threads on here it looks like that keypad can be added to our trucks. I don't know anything about it other than I've seen post on it in the past.
Good luck on getting her fixed.
Old Jul 20, 2007 | 09:10 AM
Beerstalker's Avatar
Beerstalker
The keypad can only be added to the factory remote entry system. I'm pretty sure it won't work with an aftermarket system.
bkvanbek
Jul 14, 2016 08:48 PM
mgf250
May 14, 2007 09:30 AM
RedClifford
1997 - 2003 F150
Sep 30, 2004 06:59 PM
sportscar
Jul 21, 2003 07:59 AM
oppy
Jun 1, 2003 10:42 AM
