Low Budget Chip or Tuner Upgrades
The tapping part was the hardest part of the install for me. I was wishing I had gotten the clamp type by the end of it, but many here have said they had no problems with that part at all. Now that it is complete I am glad I got the tap type. I don't think that there is a big difference in performance of the two. Call Diesel Manor and talk with them, they were extremely helpful to me. Even saved me money on shipping. I can concur with BDDrummonds, the kit is VERY complete and the directions and diagrams are very good. I got the a-pilar set up and it was very straightforward.
If you are looking for budget gauges check out these guys http://www.glowshiftdirect.com/
I got a pillar and three gauges (boost, egt, and trans) for about $200 and install was pretty simple.
This poor guy just wanted a chip, and all of his PMS victims are giving him the disease.
Ill be the first to say sorry, its not out fault, its the truck, but ill apologize.
I got 3 gauge pillar gauge pod and a 2 guage instrument cluster pod. If your getting 2 gauges go with the instrument cluster pod IMO. If i was a manuel i would have gotten it in a heatbeat. Im auto so i got the standard pyro, trans, boost on the pillar. On the cluster i only got fuel pressure for now.
WOW! Thanks guys. Like John311t said there is a lot of responses but that's how you learn. That's why I love coming to this forum. I appreciate all the info and I will be checking out the websites mentioned. Question? I didn't really see a true opinion on wether the tap or clamp EGT sensor was better than the other. Any takers?
Originally Posted by Big Swole
yes I have an automatic, when you mean drill and tap is this something a novice should be attempting/ ie time consuming or just know how?
Joe
I mounted the pyro in the manifold. Was real easy if you take your time. Like Izzy said just go 3/4 turn and back out, go a little more and back out. Use some WD-40, and keep the tap clean and lubed. For the tap and drill bit I went to lowes and on an end cap near the power tools, I found a tap and drill set with the 1/4inch NPT tap, and letter R drill bit.
Dr. Johnson
32
02-03-2014 11:19 AM
PowerStroker94
12-28-2010 10:53 PM
low budget
108
02-03-2006 07:44 AM
