I need to fix some wiring on my power mirror- how do I take apart the plastic panel on the inside of the door? Other then unpluging window switches, where does the panel bolt to the door? How do I access the bolts?
there is a bolt under the window control bezel and another bolt in the refletor on the bottom of the door behind the lens and the you can lift the panel straight up on the front you will have to remove the small trim piece by the mirror inside it will just pull off it has a couple clips that hold it on.
hope this helps.
Billy
