Sponsored by: Auxito
DTC on 2002
Old Jul 16, 2007 | 10:23 PM
frankylo32's Avatar
frankylo32
DTC on 2002
What would these codes mean? P1633 and P0113? All help greatly appreciated...
Old Jul 17, 2007 | 08:26 AM
150mudder's Avatar
150mudder
P0113 - Intake Air Temperature (IAT) Sensor Circuit High Voltage.
P1633 - Keep Alive Memory Power Voltage Low.
Old Jul 17, 2007 | 01:53 PM
frankylo32's Avatar
frankylo32
How can they be fixed?
Old Jul 17, 2007 | 02:39 PM
KingRanchMan02's Avatar
KingRanchMan02
Reset the codes and see if they come back. Good luck!
Old Jul 17, 2007 | 10:14 PM
frankylo32's Avatar
frankylo32
They keep comin back...
Old Jul 17, 2007 | 10:25 PM
streethealer's Avatar
streethealer
My guess is that you need a battery unless you have recently replaced it. My .02
Old Jul 17, 2007 | 10:30 PM
Bluegrass 7's Avatar
Bluegrass 7
Fuse #2 on the inside panel supplies the PCM and other dash functions, ETAC, overhead console etc..
Are there any other functions not working? If yes, this fuse is blown, if no, the lead to pin 55 of the PCM is open or has a high resistence, dropping the keep alive power to the PCM, to low.
The other code is telling you the intake air sensor is open or not plugged on, harness etc.
Old Jul 17, 2007 | 11:08 PM
frankylo32's Avatar
frankylo32
Bluegrass where can this part be found so I can check it
"the lead to pin 55 of the PCM is open or has a high resistence, dropping the keep alive power to the PCM, to low."
Is that under the hood and what side? And which is pin 55?
Old Jul 17, 2007 | 11:11 PM
frankylo32's Avatar
frankylo32
And it has a new battery... forgot to mention.
Old Jul 18, 2007 | 09:10 AM
Bluegrass 7
Measure the voltage at the fuse with a meter first.
once with the fuse in place and once with it out.
There should be little difference in voltage of maybe a half volt with fuse in or out.
If a large difference; there is something from one of the circuts it feeds that is loading the line down.
The next thing to do if this condition is found is to put a small interior lamp in place of the fuse and disconnect circuts that are hooked in, to see when the lamp dims.
The fuse is a 5 amp so the current is probably small unless it has blown the fuse.
The PCM is on the riders side behind the kick panel. I doubt the trouble is at that location.
Old Jul 18, 2007 | 11:29 AM
frankylo32's Avatar
frankylo32
What is the fuse for? ie. PCM or what? the problem that this is happening on is a 02 Stang with the 3.8 and I figured that they might be alike. I did check the fuse and it stayed the same with the fuse on and off.
Old Jul 18, 2007 | 01:59 PM
Bluegrass 7
This is a truck board.
I don't know what the cars have exactly for hardware, placement and hookup.
awillo0406
20
May 7, 2013 02:58 PM
MiamiPSD
Feb 6, 2013 05:08 PM
sneak
Jan 24, 2006 09:09 PM
Ultramagdan
1997 - 2003 F150
13
Jun 27, 2005 10:10 PM
