Sponsored by: Real Truck
How do I tell...
Old Jul 17, 2007 | 03:14 PM
Ace!'s Avatar
Ace!
Yeah Bill, that's the stock rubber isolator.
Old Jul 17, 2007 | 04:16 PM
redford's Avatar
redford
FTE Leadership Emeritus
The snow plow option does put heavier springs on the front.
To level the truck, you should put F-350 block in the rear, which will bring the rear up about 2 inches.
Old Jul 17, 2007 | 04:35 PM
bpounds's Avatar
bpounds
And I think it makes it ride a little rougher too. I don't know if the cooling modification is anything significant, so don't know if there is a good reason to have it. We don't plow much here in SoCal.
Old Jul 17, 2007 | 05:00 PM
redford's Avatar
redford
You could easily install softer springs up front, but don't expect miracles when it comes to the ride.
Most owners report good luck with getting new shocks (bilstein) and experimenting with lower tire pressures.
Old Jul 17, 2007 | 05:10 PM
bpounds's Avatar
bpounds
Tire pressure helped for sure. Not interested in changing springs. Shocks will be worn out in good time. Meanwhile I'm looking for a coffee sippy cup :-)
Old Jul 20, 2007 | 01:35 PM
borcht warrior's Avatar
borcht warrior
Hey fellas,
Sorry I have not been able to get a photo posted. I can't seem to figure out how to do it.
I checked a few things out last night.
I looked under about five 350's in the hotel parking lot. (no 250's available) I found that they all have a 1 inch thick rubber isolator on top of the front springs. My truck has this plus a 2" thick spacer. It looks stock but after looking at the other trucks I can see the difference.
I checked the build sheet that was on the window of the truck when it was purchased. I has a the FX 4 package and the camper package.
Not sure what the camper package is?
So my preference is to lift the back up. Can I just install the 4" blocks out of a 350? Is this hard?
Old Jul 20, 2007 | 01:47 PM
Beerstalker's Avatar
Beerstalker
Check out this thread
https://www.ford-trucks.com/forums/6...ar-blocks.html
78F150RangerXLT
Mar 22, 2009 01:56 PM
The67Beast
Offroad & 4x4
18
Nov 8, 2007 08:31 AM
fuddy
Aug 26, 2007 02:08 PM
macwilj
Jul 28, 2007 08:26 PM
