Sponsored by: Real Truck
How do I tell...
Old Jul 16, 2007 | 02:12 PM
borcht warrior's Avatar
borcht warrior
How do I tell...
Here is a bit of a newbie question. How do I tell if my truck has a levelling kit on it? I am tempted to go to the local home improvement store to start looking at all the SD's to figure it out.
My truck is an 06 F-250 with a 6.0. I bought it used from a GMC dealership and right from the day I bought it, it looked a little high up front. My buddies think the rear springs are shot but they only got 34,000 KM on them. However the truck does have a gooseneck hitch mounted in the bed so who knows.
Does any one have pic's of before and after of the a coil spring leveling kit installed? This might help me figure it out.
The only reason I am concerned is that when we were camping last week the truckers were flashng me with their headlights alot when I was on low beams
Old Jul 16, 2007 | 02:13 PM
EaTmYtAiLpIpEs's Avatar
EaTmYtAiLpIpEs
well does it have blocks on the rear leaf springs?
Old Jul 16, 2007 | 03:14 PM
redford's Avatar
redford
FTE Leadership Emeritus
When parked on a level surface, does it look level, tail high or nose high?
Are there any parts on the front suspension, epecially around the coil springs, that do not look like they came from the factory?
What size tires and wheels do you have?
How tall are the blocks between the leaf springs and the rear axle?
Did your truck get equipped with any special suspension option, like heavy dudty suspension or snow plow package?
Old Jul 16, 2007 | 04:31 PM
bpounds's Avatar
bpounds
[QUOTE=borcht warrior]Here is a bit of a newbie question. How do I tell if my truck has a levelling kit on it? I am tempted to go to the local home improvement store to start looking at all the SD's to figure it out. /QUOTE]
I don't know how to tell re the blocks. However, my truck sits fairly level and I'm pretty sure it's because it has the snowplow prep package. The camper prep package would probably do the same thing. The option gets you heavier front springs and a "special" fan. Check your build sheet for an option like that.
Bill
Old Jul 16, 2007 | 04:34 PM
redford's Avatar
redford
The blocks are just that, a block of metal that sits between the leaf spring and the rear axle. You can see it if you look into the fender around the rear tire.
You just measure how high that is with a tape measure.
Old Jul 16, 2007 | 04:47 PM
exposition's Avatar
exposition
I asked the same ques. a month ago . After being told what to look for ,I found I had a 4" lift. Does this require different shocks ? ( longer stroke ? ) . Thanks for letting me use your Question .
Old Jul 16, 2007 | 05:41 PM
jake00's Avatar
jake00
there should never ever be blocks up front.
Old Jul 16, 2007 | 05:44 PM
Ace!'s Avatar
Ace!
A leveling kit on a 2006 will be a rubber or plastic spacer on top of the front coil springs. You don't have to look for anything else. If there is a spacer on top of the coil that is more than 1 1/2 or 2" tall you have a leveling kti; however, an F250 is typically pretty even front to back, so I would venture to guess a leveling kit on an F250 will make it sit nose high.
Old Jul 16, 2007 | 06:37 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
You went camping. Did you have a trailer, fifth wheel or a slide in camper?
Old Jul 17, 2007 | 12:07 PM
borcht warrior
Wow guys thanks for all the responses...
First off my truck sits a little nose high and seems to sit higher than other SD's.
There is a spacer on top of the front coil springs but I will measure it and take pictures tonight.
I will also measure the rear blocks 2" for the 250, 4" from a 350
It did not come from the factory with the snow plow prep or the camper prep (I still have the factory window sticker) It does have the FX4 package.
Not related but we have a 23' TT that I was pulling all the time.
Old Jul 17, 2007 | 12:08 PM
borcht warrior
Sorry forgot to add that it has factory rims and tires.
Old Jul 17, 2007 | 12:28 PM
bpounds's Avatar
bpounds
I also have an '06, F250 FX4 PSD, SCLB. So we have similar trucks. I also tow a 23' Pioneer travel trailer. It has a tongue weight of about 400 lbs (probably more like 500 with full water tank). I've weighed the trailer on a trip so I know it weighs about 5,200 lbs.
So regarding your headlight aim, do you use a WD hitch and is it adjusted properly? I hoped to not need the WD hitch when buying the truck, but found that I did need it. Without it the rear of the truck lowered about 2 or 3 inches and the front lifted about 1 inch (roughly, can't remember the exact measurements). That certainly would be enough to cause your headlights to be aimed too high. With the WD hitch I could perfectly level the truck, but I found that to be a bit too bouncy so I reduced hitch tension a bit. Now the rear drops about an inch and the front is nominal. Not a serious change in headlight aim.
I'll try to get out to the lot and see what, if any, blocks I have on my springs.
Which cab and bed length do you have?
Bill
Old Jul 17, 2007 | 12:46 PM
borcht warrior
I have a weight distributing hitch as well and when i stopped for fuel I readjusted it and the lights were better.
My concern was that I might be tightening those springs a little too much. I also was just curious why the truck sits nose high with no load.
My truck is a Crew cab (4 doors) and it has the 6'6" box.
Old Jul 17, 2007 | 12:50 PM
borcht warrior
The trailer is a 23' MaxLite. 4075 lbs dry, tongue weight 425 dry. I imagine that it was closer to 600 lbs loaded.
Your trailer is quite similar in weight to mine.
Old Jul 17, 2007 | 02:36 PM
bpounds's Avatar
bpounds
Originally Posted by bpounds
I also have an '06, F250 FX4 PSD, SCLB....
Bill
Just checked, and on the front I have about a 1" thick rubber spacer at the top of the springs. It doesn't look like anything more than a regular spring cushion with the center guide boss. It could have been made thinner though, so maybe it has something to do with the snow plow option. I would guess it's just stock for a 4x4.
On the rear I have a 2" block under the springs.
Bill
