Sponsored by: Auxito
97 Power Windows ?
Old Jul 15, 2007 | 09:32 PM
Justin97's Avatar
Justin97
Question 97 Power Windows ?
Driver side window suddenly doesnt work. When I go to operate the switch the relay makes a clicking noise. I switched the relay out with the passenger side and the relay is good. The driver side still didn't work.
Could it be anything else besides the motor? if so is the passenger and driver side motors interchangable.
TIA
Old Jul 16, 2007 | 03:14 AM
KSopocy's Avatar
KSopocy
Before you dive into the motor, I would take the switch apart and clean the contacts. My 99 did the same thing.The switch will come apart, but be very careful as the tabs will break.
Just a tidbit of info, been there done that.
Old Jul 16, 2007 | 03:22 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Could it be anything else besides the motor? if so is the passenger and driver side motors interchangable.TIA
The motors do not interchange. They are rights and lefts. The motor itself may be OK, but the plastic gear in the motor may be stripped. Very common. The gear kit is available from Ford and autoparts stores.
D0AZ62234A24B .. Gear Kit-Window Motor
A parts store may ask..."early or late kit?" Y'all want the late gear kit, the one I typed above.
mrjimbov
Electrical Systems/Wiring
Nov 23, 2014 07:20 AM
Dpan63
Apr 9, 2014 05:42 AM
viker123
1997 - 2003 F150
Apr 17, 2011 09:05 AM
Carmine1913
Mar 28, 2010 09:25 PM
jklumb
New Member Introductions
Mar 31, 2008 12:25 AM
