over heating
Old Jul 19, 2007 | 12:46 AM
Mil1ion's Avatar
Mil1ion
Post #1 stated he has a 351M.
I asked about the decal because he typed both (engine family) as you noticed Eric and because it will have some info I need.
Old Jul 19, 2007 | 07:18 PM
Jermafenser's Avatar
Jermafenser
Originally Posted by Mil1ion
Your calibration code could be 7-72-R11
Do you have a red/white decal on the driver's side valve cover ?
1979 trucks had the decals on the driver's side of the hood, not on valve covers like previous years.
His decals should be brown text on white background for 49 state emissions.
Old Jul 19, 2007 | 08:13 PM
biggreen79's Avatar
biggreen79
yeah there is a tag and yes if you look at the valve cover it reads 351m/400
Old Jul 19, 2007 | 08:21 PM
Jermafenser
What colors are the decals?
All '79 decals were on the hood. All of my '79s are.
Original hood? Original engine? Original valve covers?
Old Jul 22, 2007 | 04:44 PM
biggreen79's Avatar
biggreen79
the motor is not original it out of a 78 or 79 bronco the color are orenge and white and it is on the left side vavle cover
Old Jul 22, 2007 | 04:46 PM
biggreen79's Avatar
biggreen79
the motor is not original it out of a 78 or 79 bronco the color are orenge and white and it is on the left side vavle cover valve covers are original to motor and the hood is orginal to truck the motor was in the truck when i bought it and i have got the original motor to it is in boxes what is the calibration code do or what is it for?
Old Jul 22, 2007 | 09:24 PM
Jermafenser
Most likely a '78 motor judging from that information.
The calibration code is there for factory records for settings like idle RPM, static timing, crub idle, kickdown, etc.
Old Jul 23, 2007 | 09:42 PM
biggreen79's Avatar
biggreen79
All that is listed on the tag i set the way the books seed to set it. its also at what the tag seed to set all that at but it still running rich if i lean it out to where the exhaust smells normal it bearly runs. but any idea on the overheat problem i dont want to buy a ton of parts that dont fix the problem more less i dont want to put a ton of money into something that ant going to fix my problem
Old Jul 23, 2007 | 10:45 PM
Mil1ion's Avatar
Mil1ion
You guys are talking about this engine sticker.
Not the calibration label
Calibrations label.
It actually identifies the engine in question and gives info for Vacuum hose routing & engine specs.
shown here.
Old Jul 27, 2007 | 08:17 AM
biggreen79's Avatar
biggreen79
So how do i find a vacum diagram
duckettcharlie
Aug 13, 2013 05:29 AM
cosninocanines
Jan 12, 2013 08:38 AM
expguy121
Jul 1, 2012 10:03 AM
Leemakesmepee
Nov 18, 2011 02:27 PM
bobbyg
6.4L Power Stroke Diesel
Sep 24, 2007 10:16 AM
