over heating
Old Jul 15, 2007 | 03:28 PM
biggreen79's Avatar
biggreen79
Unhappy over heating
hi i have a 1979 f150 with a 351m and it over heating i have replaced the themostat and it is still over heating. when i shut the truck off it shots a stream of coolant out the feller neck and make a bubbling sound if any one know how to fix please help me
oh and if anyone know how to set a 2brl carb and vacum line routing let me know i could use your help
Old Jul 15, 2007 | 06:06 PM
rusty7983's Avatar
rusty7983
maybe its just a bad radiator cap. it would let it bubble over, but not overheat. the radiator cap could be defective. i did one years ago like that.
Old Jul 15, 2007 | 09:19 PM
fasthauler's Avatar
fasthauler
There is not enough info to really help here.
It is normal for coolant to puke out when hot. That is why they have coolant recovery tanks on these vehicles.
Check the radiator to make sure the thing is not plugged. Check the bottom radiator hose to make sure it is not collapsing. Make sure you have a good working 15 lb cap on the radiator. Make sure the fan and fan clutch assembly are working properly. The fan clutch probably accounts for 80% of overheating problems.
Old Jul 16, 2007 | 09:38 AM
trinogt's Avatar
trinogt
I had the same problem and it ended up being a plugged radiator. Grabbed one in the junkyard that looked to be a recent purchase in the truck it was in, and worked great.
But, like mentioned above, try your cap because if there isn't enough system pressure, the boiling point of your coolant drops dramatically. Also check that you have at least a good 50/50 mix of coolant/water.
My trucks came with flex fans instead of clutch fans, so there was no clutch to worry about.
Also, the waterpump may be losing efficiency.
Old Jul 16, 2007 | 03:38 PM
Berek's Avatar
Berek
check the timing? mabe check for intake leak?, of course i put theses things in hoping it's not a head for you, always look at the simple stuff first
Old Jul 16, 2007 | 04:40 PM
Mil1ion's Avatar
Mil1ion
First things first !
Maybe you are filling the rad too full ?
The level should be 1" BELOW the inside seal for the cap.NO higher than than.
Filling higher than that will blow coolant out.
Old Jul 16, 2007 | 09:41 PM
biggreen79's Avatar
biggreen79
well guys bypassed the heat hoses and there is no clucth for the fan on this 79 it has a new cap the hoses are new coolant is flowin through the rad i thought maybe i have bad fin on the water pump it was cooling great untell i reved it upand then it started overheating
anyone know where i can find a vacum line diagram and factory carb settings
thanks for the help
Old Jul 17, 2007 | 12:17 AM
Mil1ion's Avatar
Mil1ion
You never answered the coolant level Question I asked ;(
Vacuum diagrams ?
I have that info.
I'm waiting for all the info on your truck so I know which diagram to post.
so far:
1979 F150 351M
Trans auto or manual
4x2 or 4x4
49 state or California
Factory Carb settings ?
I haver that as well after you answer the above
Old Jul 17, 2007 | 05:03 PM
Jermafenser's Avatar
Jermafenser
Hate to interfere, but since it's a related question...
Got a diagram for 1978 F-250 4x4, 400/C6, Fed. Emissions? Autozone.com skipped MY-1978 for some reason.
Old Jul 17, 2007 | 05:30 PM
Mil1ion's Avatar
Mil1ion
Yours is 7-74-R10 Jerm.
Old Jul 17, 2007 | 06:08 PM
Jermafenser
Thumbs up
Thanks once again, D. Off to write down some more numbers!
Old Jul 17, 2007 | 09:52 PM
trinogt's Avatar
trinogt
You could also have air in the system. Try parking with the front up a hill. When the engine is cool enough, remove cap and start. It should burp out the air if that was the problem, but give it some time (without boiling over!)
Old Jul 18, 2007 | 09:19 PM
biggreen79's Avatar
biggreen79
Wink
the truck is a 1979 f-150 ranger 4x4 with a 351m/400 a c6 trany ford 9" rear and a dana 44 front axle a np205 t case i hope that all the info you needed thank agian guys
Old Jul 19, 2007 | 12:19 AM
Mil1ion's Avatar
Mil1ion
Your calibration code could be 7-72-R11
Do you have a red/white decal on the driver's side valve cover ?
Old Jul 19, 2007 | 12:37 AM
Torque1st's Avatar
Torque1st
Posting Legend
No such engine as a 351M/400, you would either have a 351M -OR- a 400...
