460 Advice
Old Jul 14, 2007 | 08:16 PM
ivanogburn's Avatar
ivanogburn
460 Advice
I have a '60 f100 with a '71 Lincoln 460. the intake is stock, but the carb is a 750 cfm Carter.
I am looking for suggetstions ad the right intake and header choice to add thatextra zing to my F100.
Thanks
Ivan
Old Jul 25, 2007 | 07:50 AM
darrin1999's Avatar
darrin1999
good choice on the carter
have you changed cams? if its still the stock cam and will stay that way, id put an edelbrock performer intake in... if its anything more than a stock cam try the edelbrock peformer rpm air gap as for headers, i think youd have to have some custom made, i dont think anyone has shelf headers for a 1960 with a 460
Old Jul 25, 2007 | 10:05 AM
wizzard351's Avatar
wizzard351
wieand stealth and a 750 holley with a nice hyd cam will wake it up,and heck if ya swap intakes your half way there to swap cams too
Old Jul 25, 2007 | 12:44 PM
Tiremine's Avatar
Tiremine
Intakes you can find (I run a stealth also) but headers are another thing. Your not going to find an off the shelf header to fit your combo. I bought a set for a later model and cut the tubes off wherever they where going to hit something. (ie steering box) Bought some mandril bent tubing from Summit and routed around the box. Making a few mods to a header is alot easier than making a whole set. There's a picture in my gallery. Good luck!
Old Jul 25, 2007 | 04:38 PM
ivanogburn's Avatar
ivanogburn
Help!
So I found the number on my 1971 Lincoln 460 and it is D3VE-A2A!
So it is a 1973 Lincoln engine (or later?) and not the 1971 I was told.
So what has this cost me as far as power?
What can I do (other than beat the ***** out of the guy) to improve my engine?
<!-- / message --><!-- sig -->
What is involved in yanking off the EGR and other polution crap?
Can I pull it off completely? I thought I could.
The EGR is just a small passageway between the exhaust and intake manifold to allow a metered amount of exhaust to flow back into the engine. I understand the valve is closed while the engine is cold and at idle and only open once the engine has warmed up and is running at part-throttle. Is there a way to way to disconnect it without causing the NOX emissions to raise and detonation/knock to occur? Is it just a simple tune up after the EGR is removed?
Old Jul 25, 2007 | 05:04 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
You found D3VE-A2A on the heads, right? The block should be D1VE-6015-AB. This block was used 1971/79 on all cars and trucks. Someone may have just changed the heads. Or the engine may be from 1973 thru 1979 (except CA...no 460's were used in passenger cars after 1978 because of emissions restrictions), as the same block was used.
Old Jul 25, 2007 | 07:30 PM
darrin1999's Avatar
darrin1999
swap timing chains to an aftermarket chain or a factory one from before 1972, if a rebuild is in the budget you could go a stroker kit (521 or 545 ci- for the d1ve block id go 521) for not that much more than a good stock rebuild. rebuild the heads and replace the cam, get an intake to match the cam, all sorts of things could be done... would need a budget and goals to give a cam and intake recommendation though.
Old Jul 25, 2007 | 08:07 PM
ivanogburn's Avatar
ivanogburn
Help
After all this my budget is nothing!
I need to restore my faith in this engine with out destroying my bank account!
Old Jul 26, 2007 | 01:01 AM
darrin1999's Avatar
darrin1999
well... the timing set is pretty easy to change and will be your best "bang for the buck" at about 75 dollars, and will give you a noticeable power increase... next would be pulling the heads off and porting the exhaust a little with a die grinder. www.reincarnation-automotive.com has full porting instructions for a 25 dollar lifetime membership. shows you where to grind and not to grind. i put this second because the tools to do this cost about 80 dollars. next would be headers- which youll need to fit the engine in properly. i wouldnt bother changing the intake without changing the cam, and i wouldnt change the cam without the valvetrane to match.
my73f100
Nov 9, 2010 02:42 PM
msp1972
Aug 24, 2010 05:04 PM
shadow_almanza
Mar 1, 2010 07:55 PM
J Hodges
Mar 21, 2008 07:53 PM
kjrf100
Jun 26, 2001 06:09 AM
