Old Mar 24, 2001 | 04:18 PM
kjrf100's Avatar
kjrf100
1970 460
I bought a 1972 F-100 yesterday that had a 460 engine in the back that the guy just gave me and am wondering what info I could find out about it. It has DOVE-9425-b, F-4 on the intake,D0VE-C on the heads,and 460,and 13 on the block.From what I have learned from this forum so far is that this is a 1970 lincoln 460 with a 4 barrel. But would like to know what cc heads they are and a recomedation of cam. Thanks
Old May 8, 2001 | 06:47 PM
comet466cid's Avatar
comet466cid
what you have is a 1970 460. Heads are 75.8 cc's 10.5:1 comp approx. 360 hp. Wanna sell it?
Old Jun 6, 2001 | 03:59 PM
krossi
Guest
Posts: n/a
1970 460
No I am not interested in selling but have a question for anyone that knows, after tearing into this motor I found that it has a 4U crankshaft and the book I have How TO build Ford V8 engines it shows that to be a 429.Can anyone confirm this?
Old Jun 7, 2001 | 01:42 AM
proud owner's Avatar
proud owner
Yeap.. If it's a 4U crank, then it IS a 429 crank.. which leads me to believe it's a 429.
The only diff between the 429 is the crank(and attatched stuff, like rods and pistons, of course). The stroke is shorter, which leaves you with a higher-revving engine, great for a street/strip vehicle.
Have fun! and KEEP it!
J/.c
1965 Ford Galaxie 500 (okay, so not quite a truck)
460/C6 transplant @ 389hp/491 lb.ft.
14.29@103.8, 13-14 mpg heheheheheh
Old Jun 7, 2001 | 05:45 AM
cobrajet's Avatar
cobrajet
1970 460
the difference is the crank AND the pistons... on the 429/460 engines...
Old Jun 7, 2001 | 10:51 AM
laptopgeek's Avatar
laptopgeek
1970 460
Yuh 'wanna buy my 72 Lincoln 460? Interested parties should contact laptopgeek at earthlink.net
Old Jun 7, 2001 | 04:04 PM
proud owner
CJ.. Thats what I said..
The crank AND attatched misc. (PISTONS, RODS...)
J/.c
Old Jun 7, 2001 | 07:47 PM
Ford79's Avatar
Ford79
1970 460
I think that CJ is saying that only the crank and pistons are different, not the rods :-)
Old Jun 9, 2001 | 09:23 PM
mavman's Avatar
mavman
1970 460
yep, rods are the same in both motors. both are 6.605" long, the only difference is the pistons and crank. also, they have the same bore at 4.360"....doesn't the chrysler 360 use the same stroke as the 429 at 3.59?
Old Jun 25, 2001 | 07:05 PM
BigTex's Avatar
BigTex
Further clarification: the wrist pin height is also different. On a 429, the pin is located higher up on the piston, or closer to the ring landings. So....if you put a 460 piston on a 429 crank, it will smack the head! Good Luck with the build.
Old Jun 26, 2001 | 06:09 AM
minus's Avatar
minus
1999stroke
May 6, 2014 11:46 PM
msp1972
Aug 24, 2010 05:04 PM
straightsix4x4
19
Jun 29, 2008 11:10 PM
Hyperactive460
Mar 21, 2004 11:30 AM
sethro
Nov 8, 2001 03:33 PM
