Noisy power steering pump?
Old Jul 13, 2007 | 04:45 PM
jspringator's Avatar
jspringator
My truck is making a noise like a very a loud truck tire. Started all of a sudden. Speeds up with vehicle speed but doesn't seem to change after shifts. One shop diagnosed bad power steering pump, but referred me to a dealer. I am afraid to go to the dealer without getting advice here. Is that how a bad PSP sounds?
Old Jul 14, 2007 | 01:12 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
It might be the berrings on your truck
We thought the same thing but it turned out to be the berrings
Nick
Old Jul 14, 2007 | 01:21 AM
RangerPilot's Avatar
RangerPilot
If it speeds up with VEHICLE speed and not engine RPM, then I agree with weekendwarriorfsw32, sounds like wheel bearings.
The bearings in a pump would be affected by the RPM of the engine, and thus the RPM of the pump, not by the vehicle speed.
Old Jul 14, 2007 | 02:07 AM
dddenio's Avatar
dddenio
If it changes with engine speed, then check fluid. They make noise if they aren't absolutely full. My f350 has whined for years. It's sensitive.
Old Jul 14, 2007 | 03:35 AM
RangerPilot
Fords just tend to have noisier pumps than other brands, for whatever reason. Especially when turning at slower speeds.
Old Jul 14, 2007 | 08:53 AM
jspringator
Another shop today diagnosed bad ring and pinion and referred me to a transmission shop. I am hoping it is just a bearing in the rear end or something else cheap. I am towing the trailer to Florida on Friday. If I replace the ring and pinion I'm going to have a hard time putting 500 miles on it before Friday.
Old Jul 16, 2007 | 09:11 PM
jspringator
Rear differential Carrier bearings. Initially, the dealer called and quoted an $1,800 repair charge. I balked; told them to put it back together. I then called a private shop, who said the ring and pinions rarely go out, and that it was probably bearings. Dealer called back and then said it was only bearings and would cost $1,200. By then I lost faith in the dealer and had them put it together enough for me to take it to the other shop.
Old Jul 16, 2007 | 11:17 PM
dddenio's Avatar
dddenio
I rebuilt mine with the help of some good friends, & I think I spent $900 in just parts, so $1,200 is good I'm guessing. Just FYI.
I agree with going to the second shop, It's important to be able to trust the facility. I hate feeling taken advantage of.
Old Jul 17, 2007 | 03:10 PM
jspringator
Final quote from the second shop is $850.00. Wish I hadn't wasted that $279 at the dealer!
Davehart24
Jan 26, 2015 08:40 PM
jpcjguy
Oct 9, 2014 09:49 AM
93truck
15
Sep 5, 2013 07:37 PM
rpenterics
2004 - 2008 F150
Jul 5, 2011 11:30 AM
ktootall
Aug 26, 2005 12:52 PM
