1978 - 1996 Big Bronco
94 Front hub Problems need help
Old Jul 12, 2007 | 01:50 PM
82MustangGT's Avatar
82MustangGT
Angry 94 Front hub Problems need help
ok i have a 94 Bronco xlt 351w auto trans, it had auto hubs did the conversion kit to manual, now the dang nuts (wheel bearing )keep backing off i have tried every thing they will stay tight for awhile then all the sudden the truck will just start wobbling like crazy. i dont know what else to do
this all started about a month ago when i had to pull my cousin and his K5 out of a mud hole that had his truck sunk up to the hood..
Thanks
Josh Barber
Old Jul 12, 2007 | 02:56 PM
andym's Avatar
andym
How many spindle nuts did you put back on? On a truck with manuals from the factory, there are two spindle nuts with a large washer in between. The washer has holes in it, and one of the holes lines up with a pin on the inner spindle nut.
Old Jul 12, 2007 | 04:28 PM
82MustangGT
put both nuts back on but there was no washer, got another one ordered thanks
Old Jul 12, 2007 | 08:34 PM
dwoodler's Avatar
dwoodler
Is the little tit still on one of the nuts? If you've cranked them on a couple times you might have sheared it off. The one with the tit goes on first with the smooth side facing the bearing and the tit facing outwards. Then the washer with the indexed holes locks it from spinning and then torque the outer nut to about 35 ft-lbs (exact numbers are in the Haynes manual)
Boss08v10
Jan 31, 2012 11:21 PM
BULGOD_77
Apr 25, 2008 06:30 AM
sailboat2323
25
Mar 11, 2005 08:00 AM
94FordRanger
1983 - 2012 Ranger & B-Series
May 20, 2002 09:52 PM
L.RICH
Jan 10, 2000 03:23 PM
