Sponsored by: Auxito
Transmission help!
Old Jul 12, 2007 | 07:31 AM
jlight's Avatar
jlight
Transmission help!
Being a below average mechanic (at best), I was hoping someone here would know what to do. I was leaving my home street this morning and heard a sound like the transmission disengaged and the engine revved for a brief moment. I pulled over to listen for anything else and found that the truck would not move in reverse. It seems to go forward fine. When I put it in reverse, the rpms drop a little just like when I out it into drive. This is a 2000 F150 with the 4.6 liter, auto transmission. I really appreciate any trouble shooting direction.
Thanks!<!-- google_ad_section_end -->
Old Jul 12, 2007 | 07:54 AM
Johnny Langton's Avatar
Johnny Langton
It could be as simple as low fluid level. Check that first.
JL
Old Jul 12, 2007 | 08:03 AM
jlight's Avatar
jlight
Johnny,
Appreciate your reply. Fluid level is fine. It has $139k miles on it.
jlight
Old Jul 12, 2007 | 08:56 AM
Johnny Langton
Originally Posted by jlight
Johnny,
jlight
It may be the MLPS(AKA range sensor) on the side of the trans-have you been dealing with alot of rain and high water lately in your area?
JL
Old Jul 12, 2007 | 09:23 AM
jlight's Avatar
jlight
Johnny,
Tons of rain in the Houston area lately. We have not had any for the past 3 or 4 days, though.
jlight
Old Jul 12, 2007 | 10:00 AM
Johnny Langton
Johnny,
jlight
It's very possible that the MLPS has water infiltration damage. It was a very common problem on the '94-'95 model 4R70W's-Ford revised the sealing gasket on the MLPS after that,and it hasn't been as big of an issue....but it does happen.
That's what I would look at changing first-esp considering the rain that you and I have had in this area.
JL
Old Jul 12, 2007 | 10:03 AM
jlight's Avatar
jlight
Johnny, If I may ask, how do you check that? I would have thought that the check engine light would be on?
Thanks!
Old Jul 12, 2007 | 10:05 AM
Johnny Langton
Thanks!
No-the CEL will not light for trans isues,and there is no reliable way to check an MLPS that I've seen.
JL
Old Jul 12, 2007 | 10:24 AM
jlight's Avatar
jlight
Thanks for your help, Johnny! I spoke with a Service guy at Champion Ford in Katy and he said the odds were way against that. I will see about changing it first, though, because repairing or replacing the tranny would be pretty painful at the moment.
Old Jul 12, 2007 | 10:28 AM
MrBSS's Avatar
MrBSS
Reverse is the weakest gear, and often goes first. In my experience, it'll cost almost as much to fix it as to rebuild it. That's because they will probably have to drop the trans and open it up in any case.
Maybe somebody here can pinpoint your problem, but I think you will have to bite the bullet and find an established (and hopefully honest) trans shop. Mine did the same thing as yours at 138K. Cost me $1100. Sorry.
tyler.purrington
1978 - 1996 Big Bronco
Jan 17, 2014 02:09 PM
bsayad
Aug 22, 2012 10:19 AM
JLmissouri
16
Jan 11, 2012 02:42 AM
Justin's Green Truck
1997 - 2003 F150
Nov 28, 2010 07:27 AM
SOB Racing
May 7, 2008 12:50 PM
