1978 - 1996 Big Bronco
aod transmission issues?
Old Jan 14, 2014 | 11:45 AM
tyler.purrington's Avatar
tyler.purrington
hello, I have an 87 bronco xlt 5.0 with an AOD transmission. Recently when I shift into reverse it feels like its binding up. Before it would take a few seconds to shift into reverse and"pops into gear and now its a smooth shift and feels like it is binding up and shaking. Any help??
Old Jan 14, 2014 | 11:53 AM
greystreak92's Avatar
greystreak92
Have you checked fluid level while parked on a level surface with the transmission hot? How long has it been since the fluid and filter were replaced?
Assuming the answers to the above questions are "Fluid level is correct" and "Replaced at the last recommended interval" then its time to check other things. The AOD uses a TV Throttle Valve) cable to deal with shift points but it should have no bearing on reverse as I recall. Driveline slop including u-joints and slip-shaft should be checked as well. Check backlash at the differentials as well.
Old Jan 14, 2014 | 11:58 AM
tyler.purrington
I have checked fluid but I bought the truck about 4 months ago and have no idea when the last filter change was, just replaced the rear u joints about a month ago
Old Jan 14, 2014 | 11:59 AM
Kemicalburns's Avatar
Kemicalburns
also make sure the tranny filter didnt drop into the pan, this can cause similar issues.
Old Jan 14, 2014 | 12:05 PM
tyler.purrington
what would cause the filter to drop?
Old Jan 15, 2014 | 11:55 AM
tyler.purrington
going to change out the filter today, just discovered a ticking sound coming from the pan and a whining noise. I am completely clueless in what it could be
Old Jan 15, 2014 | 01:52 PM
Kemicalburns
yea drop the pan and see whats up. i believe that tranny will use Mercon III fluid but double check. the wrong type of fluid will burn it up.
Old Jan 15, 2014 | 07:35 PM
greystreak92
As for a cause for the filter to drop: The filter is typically sealed to the sump tube in the bottom of the transmission by a simple rubber grommet that gets pushed up over the end of the tube. The weight of the filter may be supported additionally by a bolt or two or some odd clips. Either way, incessant vibrations that come from just the engine running are enough to let bolts back out or clips slip and the filter is too heavy once filled with fluid, for the grommet to hold it up alone. Given the relatively long intervals between fluid/filter changes in automatic transmissions, and the fact that all of these parts are internal (above the pan), there is no way to inspect for these types of failures without dropping the pan. If you are going that far, you might as well replace the things that can be replaced while you have it apart.
With all that said DO NOT over-tighten any hardware during installation!
Old Jan 17, 2014 | 02:09 PM
tyler.purrington
I replaced the filter and gasket, seemed like the old filter was gummed up. Still getting a whining noise and a ticking from the trans. But as far as the reverse issue, it doesn't shake when I turn my tires slightly.
ovalhead72
Jul 18, 2016 06:23 PM
tempest411
Apr 9, 2014 06:17 PM
aiminforthesky
Nov 1, 2004 09:28 PM
MetallicaFan39
Apr 21, 2004 11:06 PM
