69 brake rotors
Old Jul 11, 2007 | 10:23 PM
blown33's Avatar
blown33
69 brake rotors
is there a rotor that has ford car bolt pattern that will fit the f-100
Old Jul 12, 2007 | 04:23 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Sorry, no.
Ford passenger cars have either a 4.50 or a 5.00 bolt pattern, F100/150's have a 5.50 bolt pattern.
Old Jul 12, 2007 | 12:48 PM
blown33's Avatar
blown33
thanks i didnt think so
Old Jul 27, 2007 | 02:10 PM
stroker393's Avatar
stroker393
I did the disc conversion on my 69 Ranger three years ago but I could not find any aftermarket wheels that I liked. After roaming salvage yards for months and cross checking rotors compared to the 79 truck donors I had from the conversion (bearing dia size and bearing part #'s) I found that rotors from a 72 LTD II have the same bearings and are 5x5 bolt pattern. I have had no problems with this setup and the American torq-thrust II's look great too.
Old Jul 27, 2007 | 02:27 PM
stroker393's Avatar
stroker393
Also setting up the rear for the 5x5 is simple. I also got the drums from the 72 LTD II, purchased new studs and removed my axles from my 69 Ranger. Took everything to my local machine shop and they redrilled my axles, installed new studs - 5x5 bolt pattern in the rear.
arkredneck
1978 - 1996 Big Bronco
Feb 14, 2016 08:44 PM
tfdcapt
Aug 25, 2013 08:57 PM
makthenif
Aug 28, 2011 08:31 AM
nebechanezer
Feb 28, 2011 11:05 AM
Eric K
Apr 24, 2007 04:36 PM
