Cleaning Fuel Selector Valve
Old Apr 6, 2016 | 10:26 AM
roots4thought's Avatar
roots4thought
Originally Posted by subford
O-ring on shaft:
88 fuel system:
Fuelres2:
Fuelres1:
dfres:
Any way I can get these pictures? Tank valve bad on my truck
Old Apr 6, 2016 | 05:52 PM
subford's Avatar
subford
Deleted old images.
Old May 3, 2018 | 01:15 AM
slackjaw's Avatar
slackjaw
5th Gear
My tank valve is bad. Any chance of an image repost?
Old May 3, 2018 | 07:53 AM
subford's Avatar
subford
Reposted:
88 Fuel system
Attachment 280309
O-ring on shaft
88 fuel electrical
Old May 3, 2018 | 09:32 AM
slackjaw's Avatar
slackjaw
5th Gear
Thanks. How do I get the bottom plate off? Thats where I got stuck when pulling this apart.
Old May 3, 2018 | 09:50 AM
slackjaw's Avatar
slackjaw
5th Gear
If you unscrew the bottom the gasket will stretch and then you will have to buy a fuel filter for an 86 Bronco II to get a new one (throw the filter away).
They are not sold separately.
I unfortunately took the bottom apart. Is this the filter you're referring to?
https://www.rockauto.com/en/moreinfo...sn=579&jsn=579
Old May 3, 2018 | 02:14 PM
subford's Avatar
subford
Looks like it.
Old May 3, 2018 | 04:07 PM
Azryael's Avatar
Azryael
I'm wondering if I can clean up and restore proper function to the selector valve in my diesel... new one lists for over $300.
I also believe the brass floats have cracked and are filled with diesel, giving lower readings than the tanks are actually at, even after a replacement switch the readings are still below F on both tanks when I've just filled them up.
I saw a fix somewhere on replacing those floats with something else, but I can't find it anymore.
Old May 6, 2018 | 12:01 PM
yellercat's Avatar
yellercat
Hat tip to subford !
Great photos of the mechanical selector valve.
Mine on the bench now and not sure if it will rebuild or not.
Anyone know if there is a 'soft' parts kit?
May be the only hope for this one!
rj1983
Aug 7, 2017 03:57 PM
KHflatbed
Oct 12, 2016 09:58 PM
Ezalycasaid
Jul 28, 2016 09:58 PM
bmxerbrett
Jun 5, 2016 01:29 PM
Jonnys.1991
Apr 11, 2016 08:18 PM
