Aerostar Ford Aerostar
Cruise control stopped working
Old Jul 8, 2007 | 10:38 PM
RandB's Avatar
RandB
Hello Aerostar experts -
We have a 93 AWD XLT. Recently the cruise control stopped working. What is the most common cause of this? Can you suggest which things to check? We are hoping it could just be a sensor or something relatively simple, hoping not to have to get involved with pulling the steering wheel or anything like that ! Thanks..
Old Jul 9, 2007 | 12:12 AM
krankshaft's Avatar
krankshaft
The most likely component to cause this is the clockspring under the steering wheel.
Old Jul 9, 2007 | 01:33 PM
lv2race's Avatar
lv2race
Is your airbag light blinking a code?
Old Jul 9, 2007 | 02:40 PM
FordBoypete's Avatar
FordBoypete
Krankshaft is right! Clockspring seems to be Most Common Cause of failure of cruise in these great vehicles, and you do need to R&R Steering wheel & the SRS device.
You can check your fuses etc, & external connections et al, but it is usually a wishful waste of time IMHO. Especially if you get a code beep with key in Accessory position.
FBp
Old Jul 11, 2007 | 06:01 PM
RandB's Avatar
RandB
There are no codes flashing or beeping. Horn works OK, no problems indicated with airbag, if these things help...
Old Jul 11, 2007 | 06:09 PM
FordBoypete
Then check my 2nd sentence "list", it's probably one of those that I dismissed as being a wishful waste of time.
Meanwhile I'll see if I can find that link to a schematic of the system here somewhere. Or maybe 96_4wdr will catch this & refresh my memory on that link. . . .
FBp
Old Jul 11, 2007 | 06:31 PM
krankshaft's Avatar
krankshaft
The clockspring has multiple contacts for the three systems airbag, cruise, and horn. Any of them can go without affecting the other.
A continuity test from the cruise control wires into the clockspring to the vehicle harness will point out if the clockspring is at fault.
If you do find a bad fuse in the cruise circuit then something has to caused it to blow and it will require further troubleshooting.
Old Jul 11, 2007 | 11:07 PM
ken1mod's Avatar
ken1mod
check the vacuum hose behind the brake booster. That was my problem.
Ken
Mitchell_Texas
Aug 22, 2015 07:14 AM
willow460
Feb 3, 2015 10:40 AM
texastransplant
1997 - 2003 F150
Feb 10, 2009 12:31 PM
RobbyMartin
1997 - 2003 F150
13
Nov 23, 2008 11:12 AM
cadjak
Jul 7, 2006 06:36 PM
