good cheap shocks?
Old Jul 8, 2007 | 07:23 PM
N8N's Avatar
N8N
good cheap shocks?
Looking for economical replacement shocks for a '93 2WD. Anyone got any good recommendations? Just looking for decent ride and long life, not lifting/lowering or anything like that.
thanks,
nate
Old Jul 8, 2007 | 07:50 PM
msb71's Avatar
msb71
Just get some Monroe's shocks , they're available pretty much everywhere.
Mike
Old Jul 8, 2007 | 08:50 PM
bradshaw6243's Avatar
bradshaw6243
Old, but not too old
I second that suggestion, get you some Monroe shocks, put them on yourself, and you will be good to go for quite a while. Also, you will save a ton of money for a little work.
Old Jul 9, 2007 | 06:49 AM
92F150Flare's Avatar
92F150Flare
Welcome to FTE
I agree with everyone.........running SensaTracs on mine now. Doing your own install can often save you a bunch but Monroe runs the "free Install" deal often. They also have a buy 3 get 1 free deal a lot.......I found that at Advance when I bought mine.
Good Luck
Bob
Old Jul 9, 2007 | 07:30 AM
N8N's Avatar
N8N
cool, I'll check 'em out. I have to admit after years of messing with VWs and Porsches I don't know what are good brands for American cars and what are not...
thanks
nate
Old Jul 9, 2007 | 09:37 AM
TorqueKing's Avatar
TorqueKing
I just put Pro Comp ES9000 on my '95. My old ones were worn out, but these made a huge improvement on road and a bigger difference off road. They're a little bit more firm than a stock replacement.
I got mine at Summit Racing for $37 each, and I think the $30 rebate offer may still be good for buying 4.
Old Jul 9, 2007 | 05:54 PM
lostin90s's Avatar
lostin90s
I put NAPA shock on my truck really cheap and ride decent. I stick with stock style (monroe ) Shocks . Make my back happy.
LOST
Old Jul 9, 2007 | 06:00 PM
ncguy23's Avatar
ncguy23
Just finished doing this on my truck, monroe sensatracks front and back, along with new springs.
Rides sooooo much better, but still a little stiff
Old Jul 9, 2007 | 06:03 PM
alxsnmr's Avatar
alxsnmr
I used monroes on my bronco, but I priced them locally and then at rockauto.com. They were quite a bit cheaper there than at the local parts shop.
Old Jul 9, 2007 | 08:11 PM
N8N's Avatar
N8N
just did it... my FLAPS had them in stock, a little pricey but still I could pick them up after work. Took me maybe an hour and a half to swap all four. That was easier than the little kraut burners I'm used to working on, I didn't even need a jack! One front shock was completely blown, that probably explains why it felt a little floaty. It still feels a little loose with the "bounce test" but then again I'm used to Porsches etc. with much stiffer suspensions, we will see when I get a chance to take it on the highway again.
nate
Old Jul 9, 2007 | 09:47 PM
N8N's Avatar
N8N
WOW what a difference. you don't realize how bad something is until you fix it I guess 137K on the truck and the shocks looked like OEM... I put the Monroe Sensatracs on, I'd still prefer a little more damping but overall it is reasonable, but the thing that got me was MUCH less dive under braking, well worth the $$ and time.
If only everything were that easy...
nate
king-david
Jun 19, 2014 05:31 AM
jspence105
May 24, 2014 08:37 AM
F 250 6 liter
Feb 10, 2011 06:19 PM
sinjin90
1978 - 1996 Big Bronco
22
Mar 30, 2004 08:33 PM
cefudge
Jun 26, 2002 07:51 PM
