Sponsored by: Kumho
rear shock mounts
Old Jun 25, 2002 | 01:29 PM
cefudge's Avatar
cefudge
rear shock mounts
look'n at a 1979 ford f150 4x4 with inline 6. good truck for 750 bucks but the rear upper shock mounts are busted. How do I replace? looks like the originals where rivoted or welded. any suggestion?
Old Jun 26, 2002 | 04:15 PM
Maxduty's Avatar
Maxduty
rear shock mounts
First grind off the rivets and take out the old shock mounts. I had a machinist friend measure the holes and make me some new mounts. They are flat plate (1/2 I think) with a big bolt welded through them. He measured my shock eye and turned down the bolt to fit, then rethreaded. He also welded in 3 small triangle braces around the bolt. We bolted them on with grade 8 hardware and now I can use double eye shocks instead of a post/eye style. These are much easier to find if you lift your truck. The setup is used on a 79 1 ton mud truck and they've held up great.
Old Jun 26, 2002 | 07:51 PM
dan15000's Avatar
dan15000
rear shock mounts
hwyhogg
WTB - Parts & other
Sep 23, 2011 08:12 PM
pym
Sep 11, 2011 11:57 PM
69crewcab
Mar 20, 2009 03:54 PM
49willard
15
Feb 4, 2006 10:25 PM
