changing front brakes
Old Jul 8, 2007 | 05:48 PM
muddogger494's Avatar
muddogger494
i need help have a 1990 ford ranger i need to get the calipers off to change out the brake pads how do i get the pins out of the top and bottom of the caliper
Old Jul 8, 2007 | 07:59 PM
jrfateranger's Avatar
jrfateranger
Drive them out with a punch while squeezing them together with pliers throw them away and install new ones, they're cheap!
Old Jul 8, 2007 | 10:22 PM
fflintstone's Avatar
fflintstone
+1, assuming you've turned them out as far as the threads will go. As jrfateranger said, buy new ones. If you have to drive them out, they're probably corroded to the point that even if you clean them up, they'll corrode again quickly and jam. Don't forget to clean the calipers and steering knuckle well where the friction surfaces are and smear a film of wheel bearing grease on the same surfaces.
Fred
Old Jul 9, 2007 | 08:23 PM
muddogger494
thanks i was at wits end trying to figure out how to get them out everything is back together and the breaks work great thanks again for the help
Old Jul 9, 2007 | 08:50 PM
jrfateranger
Glad everything worked out. Just think, you probably just saved yourself about $100.00 and you have the satisfaction of doing it yourself.
Old Jul 9, 2007 | 11:25 PM
BuffmanLT1's Avatar
BuffmanLT1
I was suppose to get new pins when I got my new calipers. Never did. I've been using the ones on there fine. I suppose I'll buy some new ones when it gets new bearings,rotors, and pads in the fall
Old Jul 11, 2007 | 03:17 AM
muddogger494
yeah and i enjoy doing this kind of stuff myself gives me a real sense of satisfaction. now i know where to go to get the info i need to work on my truck. thanks again for your help.
daveplot
Aug 21, 2015 05:46 AM
bigtexan99
Oct 24, 2014 01:14 PM
jgilrfr
Oct 9, 2010 11:02 AM
chuman
Aug 4, 2003 12:17 PM
