Electrical Question (Headlights)
Old Jul 8, 2007 | 04:44 PM
BushyTea's Avatar
BushyTea
Well looks as though I might be coming up with alot of questions lol. I got the spark plugs figured out and the truck runs great. Now I am working on some of the electrical as someone has butcher the wires.
My turn singnals, brake lights and all those work but the headlights do not work at all. No low or high beams and I have replaced them with new bulbs as well. Any ideas on why they would just quit?
Also would there be any kind of wiring diagram or something of the sort for some of the wires on the inside because my fan switch doesn't work but the wires there are all mixed also.
Thanks,
Mike
Old Jul 8, 2007 | 05:17 PM
Darth Cobra's Avatar
Darth Cobra
Check this out. It's what I plan on doing.
https://www.ford-trucks.com/index41.html
Good Luck
Chris
Old Jul 9, 2007 | 12:35 PM
BikerDude's Avatar
BikerDude
FREE wiring diagrams
Go to www.painlessperformance.com and download the 20 circuit Ford Bronco Harness installation manual. It is manual number 90521. It has some great wiring diagrams in it for the entire vehicle. Great, very inexpensive resource that you can save to your computer and print what you need to have in your toolbox!! Just make sure that you are referring to the original diagram since it will show the proper color codes.
Old Jul 9, 2007 | 05:08 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by BushyTea
My turn singnals, brake lights and all those work but the headlights do not work at all. No low or high beams and I have replaced them with new bulbs as well. Any ideas on why they would just quit?Thanks, Mike
Were the headlamps working at one time? If so...the dimmer switch will cause the headlamps to go out if it's bad. Common problem on older Fords.
The scenario: Lights are on low beam, the dimmer switch is depressed, lights go out. Try depressing the switch, see if the headlamps come back on.
C0TZ-13A024-A .. Dimmer Switch (Motorcraft SW-263)
The same switch was used from 1960 and later on all the cars and trucks.
Old Jul 10, 2007 | 09:56 PM
BushyTea's Avatar
BushyTea
Well the truck hasn't really been driven or used over the past few years but I am getting some things back fixed to make it road worthy again.
The headlights DID work before and now just don't. I hit the dimmer switch and get nothing out of them. All other lights work.
I am going to check the grounds for the headlights but after that I am kind of stumped. I do know the truck could use a rewire job but right now I don't have time to do it but need the truck back on the road again.
Thanks,
Mike
Old Jul 11, 2007 | 03:59 AM
NumberDummy
Thanks,
Mike
If you hit the dimmer switch, and nothing happened..the dimmer switch is bad. The same switch has been used since 1960, is available everywhere and are cheap. Possible loose connection, wiggle the plug.
Old Jul 11, 2007 | 08:21 AM
Flyn66dtmn's Avatar
Flyn66dtmn
I agree with Number Dummy, 95 percent possibility that it's the dimmer switch. change out the switch and when you have it apart make sure to check the wiring connection, they also get corroded to the point they will not make contact anymore. also make sure that the new switch is grounded good, i believe that the switch has to be grounded to the body before it will work. been awhile since i've worked on that so i dont know that for sure. dutch
Old Jul 12, 2007 | 11:47 PM
TonyChrist's Avatar
TonyChrist
That just happened to me yesterday!!! 1966 F100. My outage was eratic. I reached under where the switch is to wiggle wires and found the culprit 20 minutes ago. Acts like bad connection, for whatever reason. Hopefully won't go out on that pitch black mountain road I travel every morning at 3:30am.
Old Aug 13, 2007 | 05:20 AM
EDMist's Avatar
EDMist
I ran into the same problem over the weekend and found 2 black ground wires on the drivers side radiator support werent getting good contact. i cleaned them off and my headlights came on.
Gigemags05
Nov 17, 2014 04:36 PM
5280
Jul 26, 2014 02:29 PM
eignub
Sep 17, 2009 03:58 PM
loyal
Electrical Systems/Wiring
Jun 14, 2009 03:46 AM
sethro
Aug 19, 2003 12:18 PM
