My 83 ranger longbed
Will a boss 302 fit in that engine bay?And if not what's the most powerful motor I can fit in that thing?And what transmissions would mount up to the 302 or a motor that will fit my truck.The help would be much appreciated.
Thanks friends.
Yup...302s will fit without too much difficulty, though get used to changing spark plugs through the wheel wells and the like. Of course, kiss A/C goodbye.
Remember that the 302/5.0L came in the Explorer, which shared lots of common structural parts with the Ranger. Thus, mounts and the like are easy to find.
The most powerful motor you could fit? That'd probably be the 460. Will it fit easily? No way. But you can shoehorn one in there if you absolutely need tons of power.
302 and 351 are some of the easier swaps. 460 is a lot more work, so I'd say go for a built 302 or 351 just because of the aftermarket they have. The 4.6L is also a possibility, and we have a member here who put a 4.6L DOHC in the Ranger. Considering the size of the DOHC, it makes the 302 or 351 look like a cakewalk.
The V8 swap is well documented on here. On the main forum page you can do a search for "V8 Swap" and get lots of previous posts that should be able to answer most of your questions.
Depending on what kind of speed you want, what kind of rear end gearing you would like, several different choices of transmissions are available.
Do you want this engine EFI or carb? Auto or manual?
If you're going EFI on the engine and want an auto tranny, all you'll need is the appropriate computer to run the transmission as well, if it is an electronic transmission. If you want to go carbed, you'll need to pick between an electronic transmission (such as the E4OD) or a non-electronic transmission (such as the C6). Electronic trannies will need stand-alone transmission computers.
For the 302 or 351, you can get any kind of small block V8 patterned transmission. For the 460, the C6 is about the only option that can stand up to the power. If you end up building up the 302/351, you'll pretty much end up needing a C6 as well if you want to go automatic.
For manual, with a well build 302/351, or with any 460, I highly suggest finding a ZF transmission, just for the benefit of the OD gear, and the wonderful strength these posses.
There are adaptor plates to run transmissions from other manufacturers as well if you so desire, as well as to convert small block to big block bolt patterns. Just takes some careful mixing and matching.
NOW, if you decide to go 302, I assume you'll build it up for more power. I'd suggest the AOD for automatics. It's got a good set of ratios for racing, even better so if you can find an SVO AOD, and is quite durable. I would still suggest getting an adaptor to run either a T-5 or a ZF tranny (if you want to run incredibly high rear end gears, such as 5 something, I suggest the 'vette ZF), as few other manual transmissions can compete with them on a durability level.
And on the topic of rear axles, you'll need to beef that up. I'd suggest the 9". It's easy to get ahold of, has a huge ratio selection, and is about as bulletproof as rear axles come.
Fred
I may end up getting a newer ranger(91 and up). I love my 83 but I can't help but think it might do me some good in the long run to do this to a newer truck. Again, I thank everyone for all the help and suggestions.
This'll take a little more time cause some intake modifications are involved. Holly used to make a special dual plenum intake for the application because the coolant passages are reversed. The Windsor block is considered extremely strong compared to the cleaveland block. It drove Cleaveland racers nuts. The main bearing caps in the Windsor are massive even with the two bolt. From what I remember from the old Hot Rod magazine article, Just replacing the main cap bolts with studs made the bottom end indestructible for anything short of using a blower. I think its a worthy endeavour just for the 'cool' factor. We watched an oval racer outside of Windsor(ironic) win a few races whith a car he called 'The Cleavor' complete with graphics of a crazy eyed devil with a butchers cleavor dripping with blood on the side of the car. The crowd LOVED it. And it 'screamed' around the track. He ran a single plane intake with a Holley 4 bbl.
Back then, guys were used to manually tunning timing advance and carb float levels(Holleys' floats were adustable in the car.) You judged rich or lean by tailpipe and plug colour as well as performance. You also got an assortment of vaccum diaphrams for timing secondary opening. If you go EFI, you might find someone who can custom program the ECU for you, and even teach you how to play with the parameters.
I'll see what I can dig up myself for you on it. I've always had a soft spot for this buildup and wish I had the opportunity to do it myself, 'one day'
Fred
Smoke'em if you've got 'em
https://www.ford-trucks.com/lc/lc.ph...351Cleavor.htm
Some tech info
https://www.ford-trucks.com/lc/lc.ph...evor_engine%2F
If your ebay inclined
http://cgi.ebay.com/ebaymotors/351-C...spagenameZWD1V
An FTE member with a 351 Windsor in his 89
https://www.ford-trucks.com/user_gal...?albumid=15112
More tech
http://www.darkhorseracing.net/clevor_head_mod.htm
A proud builder
http://video.google.com/videoplay?do...87181372033485
This info was pretty easy to dig up, but I misspelled. I'ts 'clevor'. Keep in mind that you'll be buying parts that are custom to the application including pistons and intake, if they still have them. There 'are' great Windsor heads available but may be pricey, but you can use cheaper intakes and valve train components. All you can do is research and decide.
Fred
