edelbrock performer intake
Old Jul 18, 2002 | 05:48 PM
51truck's Avatar
51truck
Going to install performer intake and carb this weekend, and tips on installation going on a 351w. Thanks
Old Jul 19, 2002 | 08:56 AM
georgedavila's Avatar
georgedavila
If you don't have it, go to Edelbrock's website and print their intake manifold installation instructions.
http://www.edelbrock.com/automotive/index.html
It's very important to follow their surface prep and gasket instructions.
Old Jul 19, 2002 | 09:43 AM
lghtningstruk's Avatar
lghtningstruk
I personally would toss out the end gaskets that come in the gasket kit and apply a thick bead of silicone in these areas.
Old Jul 24, 2002 | 07:55 AM
jwtaylor's Avatar
jwtaylor
The intake install is a breeze and the carb is very easy to change rods/jets very nice in my opinion.
Something to keep in mind more likely than not the adapter plate for your throttle linkage will not line up right no matter what you do and when you do line it up on the intake your pedal travel will be half what it usually would be so expect to do some modification to take full advantage of the pedal. Good luck and I will second the idea that the small gaskets should be tossed and silicone used instead, nothing like realizing that the gasket broke anyway after you torque it down or hear a vacuum leak after you bolt everything down and start it up. Good luck
Old Jul 24, 2002 | 03:12 PM
TorqueKing's Avatar
TorqueKing
the Canadian
Mar 22, 2011 09:44 AM
79fordslug
Sep 2, 2010 10:20 AM
TruckChick08
1983 - 2012 Ranger & B-Series
Aug 4, 2007 09:12 AM
broncoholic
Mar 3, 2005 10:14 AM
51truck
Aug 1, 2002 04:44 PM
