Tailgate Latch Handle
Old Mar 28, 2014 | 01:42 PM
KsCop's Avatar
KsCop
My old tailgate latch handle was bent and looking pretty sad, so I got a nice new one to install. They look identical but I can't get it to work.
The latch installs fine, but when I go to use it, it POPS over the mechanism that pulls the rods and won't open the tailgate.
Has anyone seen this? Any ideas?
1985 F150
Old Mar 28, 2014 | 04:48 PM
Gary Lewis's Avatar
Gary Lewis
I don't understand what pops. The latches have rods that go into plastic inserts in the holes in the handle. What goes pop?
Old Mar 28, 2014 | 05:20 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What goes pop?
The weasel!
Styleside tailgate handle same 1980/86 F100/350, 1987/91 is different. Rod clips are the same 1973/96 F100/350 also used as door lock cylinder rods clips on cars.
Clips available from Ford and a gazillion autoparts stores.
1983/86 tailgate-lower pic.
Old Mar 28, 2014 | 05:22 PM
Gary Lewis's Avatar
Gary Lewis
The weasel!
You are in high form, Bill! Must be due to the company you are keeping.
Old Mar 28, 2014 | 05:35 PM
KsCop's Avatar
KsCop
Let's see if I can explain..
The rods clip into a plate that rotates on a pivot. The handle has a pin that pushes down on the rotating plate when you pull the handle.
In my case, that pin appears to be POPPING past the rotating plate, thus not pushing down on it and thus not turning the plate and thus not pulling on the rods..
Mine does not look like Bill's diagram. I'll see if I can get a pic posted.
NumberDummy
Add SteveBricks to the menagerie. He swung by earlier today, picked up Mr. Clean and off they went to lunch with Adrian from IB Brands.
Adrian paid too, probably pleasing Mr. Clean who is sooo cheap, he wouldn't pay a nickel to watch an ant eat a bale of hay!
Old Mar 28, 2014 | 05:49 PM
Gary Lewis's Avatar
Gary Lewis
Tim/KsC - Tomorrow I will look up one of my handles and figure out what you are saying. And maybe take pictures.
Bill - Yup, sounds like the guy I know. I'll bet they had an interesting conversation over lunch. Did your ears burn like mine did?
Old Mar 28, 2014 | 05:55 PM
KsCop's Avatar
KsCop
Here is a pic. The 'pin' you see looks like it should hit the plate and push it down. In practice, it slips by the plate and 'pops'
Old Mar 28, 2014 | 06:06 PM
NumberDummy
1980/86 Styleside tailgates: They look the same, but looks can be deceiving.
Is the tailgate...when opened, supported by cables or metal hinges, known as scissors?
If scissors, this is a 1980/82 tailgate, the scissors are made as part of the R/L latches, so if the latches go bad, you have to replace the whole enchilada.
And...the 1987/91 Styleside tailgate is different from 1980/82 and 1983/86...as is its handle.
Old Mar 28, 2014 | 06:14 PM
Gary Lewis's Avatar
Gary Lewis
I wouldn't think either the 80/82 or 83/86 handle would pop past the pin. Sounds like a thin or poorly made handle.
Here's what one of mine looks like:
Old Mar 28, 2014 | 06:28 PM
NumberDummy
Originally Posted by KsCop
My old tailgate handle was bent, so I got a nice new one to install.
Hmm, where did you buy it...LMC?
If so...this could explain the problemo, cheap made in China crap.
Comparing quality repro parts vs LMC's crap parts is like comparing oats.
Fresh oats can be bought at feed stores, other oats can be found on the road after the horse passes by.
You get what you pay for. Buy the best and cry only once.
Old Mar 28, 2014 | 06:33 PM
KsCop's Avatar
KsCop
Didn't get it from LMC, but I'm not sure where I did get it from.
It looks just like the original, but...
I might look to Green Sales or MACs..
Old Mar 28, 2014 | 06:36 PM
NumberDummy
Green Sales sells genuine Ford obsolete parts, Mac's sells repro parts.
btw: I goofed when I said 1980/82 handle is different than 1983/86, it's the same but there are two types of handle finishes, cadmium or chrome.
E5TZ-9943400-A .. Cadmium Finish / E5TZ-9943400-B .. Chrome Finish.
Old Mar 28, 2014 | 06:39 PM
Gary Lewis's Avatar
Gary Lewis
btw: I goofed when I said 1980/82 handle is different than 1983/86, it's the same but there are two types of handle finishes, cadium or chrome plated.
Glad to hear that as I have an 85 I was planning to put in Dad's 81. Then, when you said they are diff......
Old Mar 28, 2014 | 07:44 PM
KsCop's Avatar
KsCop
I decided to order an OEM part from NOS. The chrome one.
A little pricey, but if it works I'm happy. That handle gets a lot of hard use..
We'll see when it gets in..
