radiator question - pressure washer
Old Jul 6, 2007 | 07:20 AM
GAFordBuyer's Avatar
GAFordBuyer
With summer here I've amassed a large enough collection of 1/2 splattered bugs on my radiator to start a professional entomology exhibit. This may be a dumb question, but I've got a Suzuki 4-wheeler and I need to be careful, when cleaning it, not to get the pressure washer too close to the rad as it can bend the small fins in it. The radiator in the truck seems much sturdier, and doesn't get anywhere near the abuse that the wheeler does (mud, rocks, more mud, branches, etc) but my questions are
1. any reason to avoid hitting the rad full blast with a pressure washer to get the crispy bugs off?
2. I've got the stock honeycomb front grill for now - is there anyone out there making any type of product, like a mesh net mounted behind the grill, to keep them out of the radiator? Not sure if that would be a good idea or not......
Old Jul 6, 2007 | 07:39 AM
ford390gashog's Avatar
ford390gashog
Well I assume you don't have A/C if you can see the radiator fins. The radiator fins are pretty strong but I would not use a pressure washer too close.
Old Jul 6, 2007 | 07:50 AM
NASSTY's Avatar
NASSTY
I picked up a mesh bug net thingy at Walmart.It is supposed to go over the outside of the nose of the truck.I've been planning on cutting it and putting it on the front of the a/c condensor to keep bugs out of the fins on the condensor.I haven't got around to installing it yet. For now I use a soft bristle paint brush and brush the bugs out of the fins.Sometimes I blow them out with my air compressor.
I'm not sure if a pressure washer would damage the fins or not.It may be ok if you turn the water pressure down a bit.
Old Jul 6, 2007 | 08:19 AM
Corey872's Avatar
Corey872
Not sure for your specific case, but any pressure washer I have seen would destroy the fins in a radiator pretty quick if used at full force.
If I get a bad accumulation, I usually try and soak the bug goo with cleaner or soap first - ie spray em down and let em set for 5 minutes or more to loosen the goo. Then use the pressure washer or car wash wand from 8-12 inches away and most everything will wash off.
There are products specifically for cleaning coils, too.
Old Jul 6, 2007 | 12:25 PM
corinthfireman408's Avatar
corinthfireman408
I would not spray the water directly in the radiator anyway, it seems to me it would only push them deeper into the radiator. A brush might work ok.
Old Jul 6, 2007 | 01:34 PM
VFR_Man's Avatar
VFR_Man
Mesh for grille
I just happened to see these mesh fronts in Cabela's catalog the other day:
http://www.cabelas.com/cabelas/en/templates/product/standard-item.jsp?_DARGS=/cabelas/en/common/catalog/item-link.jsp_A&_DAV=MainCatcat21412-cat20133&id=0005914520560a&navCount=2&podId=000591 4&parentId=cat20133&masterpathid=&navAction=push&c atalogCode=IH&rid=&parentType=index&indexId=cat201 33&hasJS=true
I would guess other sources have the same thing too.
Old Jul 6, 2007 | 06:44 PM
thechief96's Avatar
thechief96
I wouldn't use it too close to your grill either you may not like it if if takes off the plastic chrome.
Old Jul 6, 2007 | 08:24 PM
soxfan81's Avatar
soxfan81
please don't pressure wash you radiator ( you probally meant your a/c condenser) try to wipe them off with a dry rag be gentle and rinse them with your next car wash. Ask any a/c guy if you should pressure wash your condensing coil they will say NO! I have heard of a screen that mounts behind the honey comb grill to catch bugs. Good luck with what ever you decide.
Old Jul 6, 2007 | 08:28 PM
last5oh_302's Avatar
last5oh_302
I always thought that condensing coil was part of the tranny cooling system.
Old Jul 7, 2007 | 08:15 AM
NASSTY's Avatar
NASSTY
I'm glad GAFordBuyer started this thread.It got me motivated to get a project done that I kept putting off for the last month or so.I bought a bug screen at Walmart that was supposed to cover the nose of a vehicle.I cut it to fit and attatched it to the front of the a/c condensor with some wire ties.It works good.I just came back from a ride and there were dead bugs on the screen.I gently patted the screen and the bugs just fell off.Not bad for a $5 mod.
Old Jul 8, 2007 | 11:38 PM
GAFordBuyer
thanks for replies. Yep, meant condenser - had the radiator of my 4-wheeler on the brain when I posted. Nasty - that is a great mod - I may have to borrow that idea.....
Old Jul 9, 2007 | 11:22 AM
FTE Trigger's Avatar
FTE Trigger
A nice water hose (to keep the critter remains moving) and a fin comb should get it clean so you could "mod" over the condenser and or rad.
Old Jul 9, 2007 | 03:37 PM
Steve_Uzi's Avatar
Steve_Uzi
Personally I have a porch screen over the radiator like NASTY has. I have this on my ATV as well.. it keeps most of the big clumps of mud out... and makes cleaning the Radiator much easier! I only use a house hose to clean that radiator
xjpilot
Dec 10, 2013 08:06 AM
SonofaFord
Jul 28, 2013 11:44 PM
LipschitzWrath
Aug 16, 2010 01:29 PM
MX2004
2004 - 2008 F150
Oct 11, 2004 06:54 PM
SadButTrue
1983 - 2012 Ranger & B-Series
May 1, 2000 01:54 PM
