Washing radiator?
Old Oct 9, 2004 | 03:37 PM
MX2004's Avatar
MX2004
Washing radiator?
What do you guys use to wash your radiator when bugs are all over it? I was thinking of using my pressure washer but wanted to be sure this wont mess it up.
Old Oct 9, 2004 | 03:43 PM
pops_91710's Avatar
pops_91710
I'm not too sure about the pressure washer. I tried it on my Honda Civic and it folded some of the metal between the tubes and that was only 1200psi. Perhaps if you turn down the pressure or just backed away form it a little bit it would be better.
I wonder if there is a product out there that will emulsify the bugs so they will disintegrate with less water pressure.
The truck radiators a be a little more heavy duty than the flimsy Honda one.
Old Oct 9, 2004 | 05:15 PM
mwh's Avatar
mwh
Just use your garden hose with a pistol grip nozzle and stay back from the front of the truck a couple of feet. If you can get to the radiator through the grill with the stream, it should take off the majority of bug accumulation without damage-but try a small area with care to see what will happen. You might think about cutting and fitting window sreen material and affix it in the front of the radiator. I used the vinyl screen material since it's easier to fold in and around the braces. It's worth a try-people have used this method for years to help keep bugs from clogging their radiators........good luck.
Old Oct 9, 2004 | 05:49 PM
Steina's Avatar
Steina
CO River Rat
MX -
I wouldn't use a pressure washer.......you'd be blasting the AC condensor, which is mucho more $$$ to replace than a radiator. MWH has the right idea; put on a screen after you get it clean. One solution: www.windtrapper.com
Steve
Old Oct 9, 2004 | 07:50 PM
boomer08's Avatar
boomer08
I used a brush and lightly brushed it and hosed it off. Worked for me.
Old Oct 10, 2004 | 12:30 AM
MX2004's Avatar
MX2004
Yeah, I think I will put a screen to protect it, thanks for the help guys.
Old Oct 11, 2004 | 06:54 PM
blitzen25bm's Avatar
blitzen25bm
just brush it clean with some water and do the screen. i used aluminum and you can kinda see the metal behind the honeycomb grill it looks pretty cool. now i just crub the screen down whenever i wash the truck or finish road trips.
Grogtronics
Modular V8 (4.6L, 5.4L)
Jan 17, 2014 11:02 PM
72f2504x4390
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Jun 22, 2008 07:53 PM
ranger rules
23
Sep 24, 2004 03:30 PM
Diabolic
1983 - 2012 Ranger & B-Series
20
Apr 22, 2004 10:41 AM
Vann
1997 - 2003 F150
Aug 28, 1999 11:16 PM
