Doing my uppies
Old Jul 5, 2007 | 06:28 PM
OBX 7.3's Avatar
OBX 7.3
Doing my uppies
Getting ready to do my up pipes in a couple of weeks,just wondering,what else should I do while I'm right in there?The truck is a stocker right now but,after it's running sound and no more issues I would like to do some mods as money becomes available.One thought that comes to mind is a wicked wheel.What do you guys think?
Pocket's Avatar
Pocket
Depends on your future mods. What do you have in mind?
Old Jul 5, 2007 | 06:34 PM
OBX 7.3's Avatar
OBX 7.3
Thinking about air intake,turbo back exhaust,BTS valvebody,dp tuner,and boost annihilator for starters
Old Jul 5, 2007 | 06:35 PM
rebelchevy02's Avatar
rebelchevy02
While you there, get pedistal o rings, two sets, one for the bottom and one for the top. youll have your turbo out anyways. Also, good time for CCK, ATS housing, exhaust if you dont already have it. It would have helped to not have the down pipe there when i did mine. which was just yesterday. HPX would also be a little simpler while you have it tore apart. If your gong to get injectors one day, maybe a new turbo if its in the budget?
Old Jul 5, 2007 | 06:40 PM
ron's power stroke's Avatar
ron's power stroke
you do have gauges right??? if not..that should be the very first mod...pyro,trans temp and a boost gauge...in the mod link in my sig is some good cheap DIY mods if you want to do some reading..welcome to FTE and happy moding
Old Jul 5, 2007 | 06:41 PM
OBX 7.3's Avatar
OBX 7.3
As you can tell from my # of posts i'm still new.I know ats housing and wish it was in the budget but of course it's not,but what is CCK and HPX
Old Jul 5, 2007 | 06:42 PM
OBX 7.3's Avatar
OBX 7.3
Originally Posted by ron's power stoke
you do have gauges right??? if not..that should be the very first mod...pyro,trans temp and a boost gauge...welcome to FTE and happy moding
Yes,I have got all three
Old Jul 5, 2007 | 06:44 PM
ron's power stroke
Old Jul 5, 2007 | 06:50 PM
rebelchevy02
If the ATS is not in the budget, look into the wicked wheel, its less then 100 bucks, and works aswell, CCK is cackle cure kit, HPX is high pressure crossover line.
Old Jul 5, 2007 | 06:54 PM
OBX 7.3's Avatar
OBX 7.3
Thanx for the tips,where con I get more info on these two mods?
Old Jul 5, 2007 | 06:58 PM
ron's power stroke
best price for a wicked wheel..comes with turbo o-rings.. ask bob for an extra set to the pedastal....http://www.dieselsite.com/index.asp?PageAction=VIEWPROD&ProdID=47
the HPX you can get from ITP..dont get the rubber hose ITP has the stainles steel lines..
common mods in my sig below will lead you to some of these mods
Old Jul 5, 2007 | 07:00 PM
OBX 7.3's Avatar
OBX 7.3
Going to check this out in the AM.Thanks again for the info.
Old Jul 5, 2007 | 07:04 PM
IDPisan's Avatar
IDPisan
You will find that info and much more here!
http://www.7point3.com/mods.aspx
