all info on a 300 I6 to 460 engine swap
Old Sep 20, 2002 | 07:47 PM
scottjohn's Avatar
scottjohn
[updated:LAST EDITED ON 20-Sep-02 AT 08:50 PM (EST)]i have a '94 f150 2wd w/ a 300 I6 and have just decided to swap in a new engine. I want to find a 460 or something else with roughly the same power OR MORE that will most easily fit the swap w/ easiest mods. I ideally want a 68-72 remanufactured 460 ANY info would be helpful on changes i will have to make like bellhousing, tranny, motor mounts, gears, rad., etc. what would be the best place to look for info on prices of engines, mods, and parts.
thanks for the help, greatly appreciated
Old Sep 20, 2002 | 09:51 PM
Midnight Knight's Avatar
Midnight Knight
Do you have the money to do it?? It would be alot $$$ that you are talking about...
Old Sep 20, 2002 | 09:59 PM
HotWhlz85's Avatar
HotWhlz85
Hey Scott and welcome to FTE!!
Sounds like you have a pretty big project in mind. There are kits made to do this swap. You can find them at:
http://www.landlproducts.com/
The net is also full of webpages that folks who have done this swap put together to help others. I did a search on excite and searched for "460 engine swap" and got several pages that look to have good info. A couple of them are:
http://www.bigbronco.com
http://www.projectresponder.com/content.asp?cid=3&pid=9
Good luck,
Ron
Old Sep 21, 2002 | 11:05 AM
georgedavila's Avatar
georgedavila
The best start is find a complete 460 of the year you want, one with all the accessories. If possible, a donor car with the C6 will make everything a lot simpler and save you a bunch of money. That way you get all the trans, alternator and PS mounts and linkage.
I'd recommend you rebuild the engine and trans before even starting your swap. Check some of the past posts to determine which C6 tailshaft is required to mate with your transfer case. With the engine and trans ready to go, all you'll need is the following:
Econoline 460 oil pan
Econoline 460 oil pump/oil pump pickup
Motor mounts - I recommend L&L
Remote oil filter - L&L
L&L headers or Econoline exhaust manifolds
F250 carb linkage makes it easier
Your '94 has a computer controlled engine management system, so you'll need to perform some basic wiring for the ignition system of an early engine. Get a couple of books to make life easier.
I've been running 429/460s in a full-sized Bronco for 16 years. I've tried most of the shortcuts, F250 motor mounts, cheap remote oil filter, cheap headers and rubber lines for the remote oil filter. I recommend L&L parts for the swap because his stuff fits and is of high quality. You get what you pay for. No affiliation.
Old Sep 21, 2002 | 01:42 PM
scottjohn's Avatar
scottjohn
thanks for all the input, i know this is a big job (but well worth the time and money for me) and i knew this was the best place to get some starting info. I will keep the progress posted.
Old Sep 21, 2002 | 04:28 PM
georgedavila
My mistake. For some reason i thought you were doing the conversion to a Bronco. disregard my post.
Sorry
Old Sep 22, 2002 | 02:59 PM
scottjohn's Avatar
scottjohn
[updated:LAST EDITED ON 22-Sep-02 AT 04:03 PM (EST)]i found a site offering what looks to me to be a good deal on a 68-71 460, can anyone check it out and see if it is worth my time
thanks
http://www.rebuilt-auto-engines.com/cgi-bin/webc.cgi/st_prod.html?p_prodid=575&p_catid=119&sid=1AlF2z0W i5GFCRj-17102559398.f6
Old Oct 17, 2002 | 10:06 AM
airharley's Avatar
airharley
Old Oct 20, 2002 | 12:47 PM
chris423's Avatar
chris423
Sounds like a great project, Im considering the same swap but i would like to keep the fuel inj system, Any ideas?
Pat54632
Projects
Nov 5, 2016 08:31 AM
dylansf23
13
May 11, 2014 07:10 AM
84espy
Nov 27, 2013 10:56 AM
1959ford
Jul 17, 2003 09:08 PM
aco
35
Nov 4, 2001 08:41 PM
