Loss Of Power
Loss Of Power
Anyone have any ideas...
I recently bought a 2000 F-250 7.3L TD 4x4 120k w/ Edge PCM. Most of the time [not always], within 5-15 minutes after start, the engine will 'cut-out' for about a half-second then be fine [after severely bucking]. This usually happens at higher RPMs [around 2000] and usually happens a few times in a row[a bit of a time delay between ea.] This has been happening for a few months. No codes are thrown except when the engine severely knocks, but it is reset at power-down.
Already changed the Fuel filter, and there is no water in tank.
Any thoughts... Anyone have a similar problem?
When it does its "cut out" does the tach drop like your turned the key off? That could be a CPS failing, a 15 buck part at www.powerstrokeshop.com search part number F7TZ-12K073-B and look here http://guzzle.rbmicro.com/cps.html to replace it.
on
[QUOTE=gigi747]Anyone have any ideas...
QUOTE]
Could you explain in alittle more detail about your codes? Or are you saying your Service Engine Soon light resets at power-down? Are you using a scan reader for the 7.3L ? Not all scanners will work properly.. Any fault codes you get will remain until you reset them with a scanner..
QUOTE]
It is the "Service Engine Soon" light that resets at power-down. I used a Actron Autoscanner Plus to check the codes. Which scanners do you recommend, or what about scanning software for a laptop?
Ordered the CPS
It happens so quick that i havn't looked at the tach yet. Going to find out.
Where could I order a Factory Service Manual.
-Thanks for the ideas...
Ordered the CPS
on
the best soft ware for scanning and live readings can be had here..http://www.itpdiesel.com/store.php?c...on=show_detail
bobfromktown
01-16-2011 01:22 PM
78F150RangerXLT
03-22-2009 01:56 PM
