Wheel Width ????
Old Jun 28, 2007 | 08:40 PM
ozark1's Avatar
ozark1
Wheel Width ????
My 84 has stock steel wheels with a new set of 30X9.50R15 tires. I am going to go old school with chrome wheels and dog pans...I think the stockers are 6 in. wide..Can I go to an 8 in. wide wheel with no problem ?....or how wide ???...Thanks...Jv
Old Jun 28, 2007 | 10:18 PM
Franklin2's Avatar
Franklin2
8 inch work fine on mine.
Old Jun 29, 2007 | 12:37 AM
l8again's Avatar
l8again
Offset matters
What is the offset on your rim?
Old Jun 29, 2007 | 07:03 AM
ozark1's Avatar
ozark1
OFFSET...??...Whatever the stock Ford truck wheel came with...I am going to order a set of chrome wheels with factory offset...and perhaps a bit wider...j
Old Jun 29, 2007 | 07:04 AM
ozark1's Avatar
ozark1
I thought that 8 in. would be fine..Just did not want to order a set of non-returnable wheels...and find out then...Thanks...j
Old Jun 29, 2007 | 11:30 AM
Franklin2's Avatar
Franklin2
The extra width on mine is toward the outside. That's where you want it if you are going to run wider tires. I ran 31-10.50's on the stock rims, and when I turned a sharp turn in the parking lot, they would rub the radius arms. The chrome wheels don't do this with the same tire, since they set the tire out a little bit more.
Old Jun 29, 2007 | 05:21 PM
ozark1's Avatar
ozark1
Dave...Thanks again..I think I'll order stock backspace in a 15x10 wheel...Do you think that will be OK ?...Jerry
Old Jun 29, 2007 | 07:36 PM
Franklin2's Avatar
Franklin2
I would order a 15x10 wheel that is made to fit your truck. Stock off the shelf with no custom backspacing.
Old Jun 29, 2007 | 09:31 PM
ozark1's Avatar
ozark1
Dave...Thats what I thought..Thanks again. I like the chrome wheels with dogpans. Had a black 66 in 1976 that had them..My red/silver 84 should look as good..........j
Old Jun 30, 2007 | 10:51 AM
ozark1's Avatar
ozark1
Getting ready to order the Wheel Vintiques chrome wheels for my 84 F-150 2WD..My wheels have 3 1/2 inches backspace...Their standard Ford 15X8 that takes 10 1/8" Ford dog pans has a 4 inch backspace...Does anyone think this 1/2" will be a problem ?...Everything else the same...5 on 5 1/2..15X8...Thanks..j
Old Jun 30, 2007 | 02:31 PM
wkett's Avatar
wkett
For a 30X9.50R15 tire a 8" wide rim sounds right to me. A 10" might be a little wide and cause rubbing up front?
Old Jun 30, 2007 | 09:06 PM
Franklin2's Avatar
Franklin2
Stick your head under there and see if you have more than a 1/2" clearance from the rim and tire to the inner workings of the truck. Also turn the wheel full left and right and look under to see if you still have over 1/2" clearance.
Juniorf250
Oct 5, 2016 07:37 AM
Fat&Bald
Sep 12, 2016 09:24 PM
Shadowrider123
May 15, 2014 05:19 AM
MCD46
22
Mar 9, 2014 10:10 AM
thendrix
Oct 3, 2010 10:41 PM
