front bearings
Old Jun 28, 2007 | 02:33 PM
35l911's Avatar
35l911
front bearings
how do i get the bearings out of the stock rotors of my 2004 ranger
i tried the Haynes crappy book and i say to pry the the grease seal out of the back of the hub but how?
Old Jun 28, 2007 | 03:22 PM
cddz's Avatar
cddz
put the rotor back on and put the spindle nut on and jerk
Old Jun 28, 2007 | 03:36 PM
Alan D.'s Avatar
Alan D.
Is the whole bearing stuck, or just the race. if it's just the race, and your taking it out, get a punch and a small peaning hammer and slowly drive it out. work from side to side in a four way x pattern. Be careful not to slam your fingers or **** the race inside. i just did this 2 nights ago. It shouldn't be too hard. Haynes sucks.
Old Jun 28, 2007 | 03:37 PM
Dan Robertson's Avatar
Dan Robertson
I use a hammer and a punch. I support the hub on two pieces of wood so that the bearing is free to come out. I then reach through the front and, very carefully, place the punch on the race of the inner bearing, making sure that the punch does not damage the race that stays in the hub. I then give it a sharp whack. The bearing and seal will come out together. If you are purchasing new bearings, they come with the race that fits in the hub. The bearing races can be removed the same way.
Old Jun 28, 2007 | 04:11 PM
35l911's Avatar
35l911
ok thanks that would help didn't think to do that.
thanks it worked the punch and hammer thing worked
sorry no hondas around to assist in the other method but i know that works to from experince
Old Jun 28, 2007 | 07:59 PM
35l911's Avatar
35l911
i just took it for a test drive and it runs great no more rattle in the brake peddle and the steering wheel no longer vibrates when i stop and no more loud hum at 45mph those rotors were shot and i also found out the ceramic pad i put on crumbled in the center and were cracked all over and one pad had completely disappeared it was metal to metal
Old Jun 28, 2007 | 09:08 PM
ranger1999 Bob's Avatar
ranger1999 Bob
for the future if you just want to pop out the grease seal you can usually pop it out with a small flathead screwdriver. you tap it under there and bend it so that you can pry it out
ItsAFord55
Nov 20, 2015 02:24 PM
bassn1
May 25, 2009 06:42 PM
alankirby
Mar 22, 2006 11:30 AM
ford390gashog
Aug 3, 2004 02:05 AM
jambroson
Mar 1, 2004 10:47 PM
