Low Voltage, bad alt?
Old Jun 28, 2007 | 11:47 AM
Pest007's Avatar
Pest007
Hey guys, I was just wondering what your gauge runs at when you have the AC on and any other accessories. I have a tranny cooler fan and when I run the AC and stuff it doesn't seem like my alt charges as much as it used to, usually hangs around the lower part or "normal" around the N or O, but when everything is off it doesn't go up much, just wondering where everyone's gauge is running.
Old Jun 28, 2007 | 11:50 AM
61 uni's Avatar
61 uni
If it does that when you first start it, it is normal glow plug use. Mine runs at the "r" in normal after the glow plugs go off.
Old Jun 28, 2007 | 11:52 AM
tjbeggs's Avatar
tjbeggs
The factory guage is junk. It hardly works so as long as your battery light isn't on it probably ok. running a cooler fan and the A/C is a pretty big load so it will probably hang low for that. but as long as your battery light isn't on your probably ok.
Old Jun 28, 2007 | 12:26 PM
Cuda_jim's Avatar
Cuda_jim
If you have a volt meter take a reading at one of the batteries. At idle, with everything on you should have more than 12.5 volts. It should increase to 13.2 or higher with the engine revved to 2K RPM. The gage in the dash is not accurate.
Old Jun 28, 2007 | 12:29 PM
Pest007's Avatar
Pest007
I will give that a try, I was going to go get the alt tested at Checker or something, just haven't had time.
Old Jun 28, 2007 | 07:20 PM
WALJON's Avatar
WALJON
How old are the batteries ?
Old Jun 28, 2007 | 10:28 PM
strokin'_tatsch's Avatar
strokin'_tatsch
mine runs around the "r" sometimes close to the "m". mine used to do that and it was batteries then the cable that charges the batteries was melted where it attached to the alternator like a week after i got new batteries.
Old Jun 29, 2007 | 09:50 AM
Pest007's Avatar
Pest007
My Batteries are fairly new, just got them like maybe a year ago, Interstate batteries, and the cables are clean and look very good
