Sponsored by: Kumho
proportioning valve ?
Old Jun 28, 2007 | 09:45 AM
classicranger's Avatar
classicranger
Does anyone know if the proportioning valve for 1979 ford truck is the same if it has power brakes or non power disck brakes?
I am going to do a conversion on 1968 and i'm not sure if i am going with power or non power.
Also is there a difference in master cylinders?
Thanks
Old Jun 30, 2007 | 12:00 PM
385seriesHemi's Avatar
385seriesHemi
Run up to the parts store and find out if the portioning valve is the same for each application. they could have the same part number or not, its a 50/50 chance
Old Jul 9, 2007 | 05:36 AM
classicranger
Thanks for the advice that is what i will do.
Old Jul 9, 2007 | 06:19 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Also is there a difference in master cylinders? Thanks
Please list the exact model and series you are working on, it makes answering questions easier.
1975/79 F100/150 2 or 4 WD with disc brakes used only one valve:
D5TZ-2B257-B .. Disc Brake Proportioning Valve.
Parts catalog makes no reference concerning power brakes, so the valve will work either way.
Old Jul 9, 2007 | 12:05 PM
mark a.'s Avatar
mark a.
I'm not sure about your question. But most drum brake fronts had some sort of residual psi system for the cylinders, so you would want to eliminate that feature if the system had it and you went to front disc, power or non power.
Old Jul 9, 2007 | 04:16 PM
classicranger
Thanks i will do better when asking questions.
More info.
Mark A
Thanks, i will be starting from scratch so i will plumb it as a 79 F150 parts.
Old Nov 29, 2008 | 06:49 AM
frdavid's Avatar
frdavid
Thanks Mark for the question and Bill for the answer. This really helped me!
Old Nov 30, 2008 | 07:38 AM
rebocardo's Avatar
rebocardo
Install a mstr/booster combo for a 1979 F-350 with disc brakes for $120 from Advance Auto. You will get a much bigger mstr/booster and increased brake performance. It will bolt right in.
Old Nov 30, 2008 | 12:50 PM
frdavid's Avatar
frdavid
So does that mean that the '79 F-350 mstr/booster will bolt onto a '76 F-100?
Supercab
Mar 5, 2024 09:48 PM
BigSexy78
17
Jan 13, 2017 12:04 PM
high6
Sep 6, 2016 01:23 AM
mccolalx
Sep 18, 2015 11:12 PM
JEDWIN
Feb 22, 2012 03:46 PM
