Sponsored by: Real Truck
Snow Chains
Old Jun 27, 2007 | 11:15 PM
jantman's Avatar
jantman
Snow Chains
Hi,
I'm a relatively new owner of a 2006 F-250 XLT FX4 (CrewCab) with the LT265/17R75's (stock) on it.
I've been giving some thought to what I'm going to do for the winter. The manual specifies SAE Class S tire chains - which, I believe, are the cable-type.
Is it true that a "super duty" will only take cable-type chains? I've been around E-350/450 ambulances for quite a while, which seem to have a lot less clearance around the tires, and we've always used heavy-duty chains on them.
Any experiences with better chains that will work on this truck? I'm a volunteer EMT, and pretty much need to be able to (safely) make it through anything... never at high speeds, but getting stuck isn't an option.
Old Jun 28, 2007 | 12:54 AM
blackhat620's Avatar
blackhat620
Originally Posted by jantman
Hi,
You can run standard chains on the SD i do not know why the specified "Class S" in the manual as there is plenty of room. Maybe it was the lawyers at FMC choice to prevent any possible problems.
Here is a link to many that will fit
http://tirechain.com/16INCHTRUCKCHAINS.HTM
http://tirechain.com/275-70R-18.htm
Reinforced Diamond Pattern are the best to get for the most traction and stability.
Old Jun 28, 2007 | 01:25 AM
wlihntr's Avatar
wlihntr
i have 285/75-16 tires on my truck and i run these: http://www.tirechain.com/HEAVYTRUCK.htm every year i go hunting...if you cant get there with them...than nobody is getting there
Old Jun 28, 2007 | 10:33 AM
jim henderson's Avatar
jim henderson
I have a 94 F250 4x4 etc. The wheel clearance on mine with stock tires is huge.
I have cable chains but in 8 years of driving that truck in Oregon, I never put the cable chains on. Only a couple times that I probably should have.
So can't answer your question from experience with this truck, but from experience in cars and a small truck with chains I would say chain link is best for traction if there is adequate tire to wheel well clearance. Cable chains fit in tight places but in my opinion don't work as well, but they are smoother riding.
The negative with chain link is that the chain gets loose after say 50 or 100 miles and needs to be tightened periodically. If you don't tighten them and or inspect regularly, one of the links will break and then the chain flails around which often trashes the paint and maybe sheetmetal of the wheel well. I never had a cable break, but that is because I drove too little on them, but I would guess if they did break they would do less damage.
Just my experience,
Jim Henderson
Old Jun 28, 2007 | 10:59 AM
Ace!'s Avatar
Ace!
The clearance near the inside of the fender/bumper/radius arm, when the wheels are turned is the issue. If you go with a wider tire the clearance becomes rather tight with the wheels turned.
Old Jun 28, 2007 | 12:31 PM
bpounds's Avatar
bpounds
Jantman, I have the same truck, an '06 FX4. You have the BFG Rugged Trail tires right? I dug out my old heavy chains about 2 weeks ago to see if they were going to work. They were originally from my '88 4 x 4. I can tell you they clear just fine. As with all chains, you want to avoid sharp turns, use adjusters to keep them snug, keep speed low, etc.
By contrast, I traded away my '04 F150 and while these chains would have fit, they did NOT clear. Ford started putting the shocks outside the springs on the rear and there were other clearance problems on the front. There would be hell to pay if you used anything other than cables.
But you'll be fine on the Super Duty.
Bill
79_250RangerLariat
General Automotive Discussion
Jan 2, 2013 05:45 PM
uscgmkcret03
6.7L Power Stroke Diesel
Jul 6, 2011 05:06 AM
M Green
2004 - 2008 F150
Feb 2, 2010 07:24 PM
Kep4
Aug 25, 2009 10:34 PM
96_4wdr
Aerostar
20
Dec 5, 2005 12:51 AM
